Product Description:
The 034Motorsport 17-19mm Adapter Socket Tool is designed to allow those with 19mm 034Motorsport Stud and Nut sets installed to use their factory 17mm Wheel Bolt Wrench for tightening and loosening. The 034Motorsport 17-19mm is compatible with both standard-length and extended-length studs.
The 034Motorsport 17-19mm Adapter Socket Tool is also compatible with the factory wheel bolt wrench and has a ⅜ drive provision that can be used with impact drivers.
Features:
- Adapter to Enable the Use of OE 17mm Wheel Bolt Wrench on 19mm Lug Nuts (Stud Conversions).
- 3/8” Square Drive Provision for Use with Torque Wrench
- CNC Machined from Billet 1040 Steel for High Strength
- Zinc Plated for Corrosion Resistance and Long-Lasting Good Looks
- Small Size Makes it Easy to Store With Other Wheel Changing Tools
What's Included:
- (1x) Adapter Socket
Check it out Here!
