Originally Posted by
dabarjel
Do you also think it’s possible for the battery to be causing underboost codes? When researching the codes it seemed to be an issue with the wastegate, fuel injectors, throttle body, or MAF sensor
so your asking if the battery is directly causing the issue. kinda and kinda not. ill explain.
what is happening is that the battery, when low will cause the ecm to loose some of its information.
the ecm has three main memory that i know of. I'm sure there are more sub-versions but for simplicity, we can keep it simple for here.
when you have a low or shortage of volt / amp power the memory can get corrupted. that section that holds your remap would be subjected to that error. that part of the ecm that tells what the car needs to do when you driving.
which leads to, can the battery cause the issue? yes but indirectly. once corrupted the car will run with issues as you see now. even if the battery is running fine for now the ecm has that corruption. sample, try reducing the power on your laptop or home PC, it will not run properly.
but for the most part i would say the ecm on audi's needs a specific voltage. i don't know exactly what it is but from experience, if your battery dips below lets say 12.3 or less it can corrupt the ecm programming. why cause if your running the A/C and radio and any other accessories, it will cause the weaken battery to drop even lower. it just needs to be there long enough to cause ecm memory damage.
the corrupted ecm will make it appear that your other hardware is damaged. like the ones that everyone is telling you to replace or repair because of the codes your getting.
the ecm fix is super easy. but you must fix the cause first.
as a preliminary deduction after watching your video, the battery appears that it is sitting at a very low level of voltage. near unstable levels for audi requirements. the gauge is universal so it give a general area of safety levels. hence, if you turn on any other accessories that draw a significant amount of amperage, you will dip that voltage below usable levels. a/c is your higher power consumption accessory. use the multimeter with that load tester to see what the voltage is. if its at or below 12.3 then your battery might be too weak. also if your battery is at a low 12.xx voltage over night, it might be damaged or too weak.
so if you get me the info i mentioned, we can deduce if it is the battery or not.
if it is, just get it warrantied asap. they will get you a new one for free or very small amount of proration. i don't know what your battery warranty states. you'll have to ask them.
once you get a replacement battery then ill show you how to fix the ecm issue.
and most importantly, how to properly install a new battery into your audi. so you wont have the same issue again.
in addition to the load of the hand unit, you should also check the charging system with that new tool you got. follow the manual for that process.
