The AC currently blows warm air. I'm the third owner and the previous owner got the car taken to a reputable mechanic that diagnosed the issue as a bad compressor. After filling the system with refrigerant (not with a vacuum, just a can from Autozone) everything leaks out after an hour or so. I injected UV dye into the system and looked for any obvious leaks without removing any major parts of the car. Didn't find anything obvious. Then I removed bumper and slam panel and checked with the UV light and didn't see any obvious AC leaks. I looked around the pressure switch but I didn't remove it to check it thoroughly.
I figured since I've gone this far and the compressor is likely bad, I ordered a Nissens compressor, Accumulator, and O-ring set from FCP Euro.
Audi VW A/C Compressor - Nissens 4F0260805AH
Audi A/C Receiver Drier - Nissens 8E0820193F
A/C System Retrofit Kit - Santech 559807901
I'm really hoping it's not a leak near the evaporator core which you have to remove a lot of the interior for.
I did notice a lot of oil and gunk around the front of the engine. Are there any areas of common leaks that I should look into in that area? The previous owner said there's a leak where the oil filter housing meets the engine, but that's at the back of the engine so I don't think it's the source for all that gunk in the front. Any pointers/advice for the AC and oil leak would be appreciated. Sorry for any oversights this is all very new for me!
IMG-9183.jpgIMG-9180.jpgIMG-9119.jpgIMG-9184.jpgIMG-9181.jpgIMG-9126.jpgIMG-9122.jpgIMG-9182.jpgIMG-9179.jpgIMG-9125.jpg
