Results 1 to 27 of 27
    Established Member Two Rings GAR92677's Avatar
    Apr 28 2023
    Laguna Niguel
    Has anyone been able to buy or try out the mercracing upgraded supercharger?
    Been hearing for over a year merc racing developed a new supercharger. Has anyone seen any results from one or been able to try one? If not who does the best porting of the stock supercharger? Thanks in advance.
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Quote Originally Posted by GAR92677 View Post
    The prototype MR1900 is currently with 034 being tested. The actual finished units aren't out yet, but I believe those are close. As far as performance goes, I just saw Suited_up_to_the_9s run a PB of a 10.69 @128mph with a used Magnuson 1740 (old APR kit) in his A6 at like 2K ft of elevation (full weight). That's with a 034 STG2+ tune that he's using wmi on to gain a little fueling. If that's not a glimpse of what could be possible with a off the shelf bolt on TVS 1900, then I don't know what is.
    If you want to go ported and you want the best, there is Jokers is the shop to go with.
    Sent from my SM-S908U1 using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Apr 28 2023
    Laguna Niguel
    Yes looking forward to seeing some fast cars still using supercharger.
    Apr 29 2018
    I feel the same way. The thought of putting a turbo convertion on this engine never excited me. Im all about the instant throttle response and linear power band of the Supercharger.
    Sent from my SHT-W09 using Audizine mobile app
    Veteran Member Four Rings 01northernS4's Avatar
    Oct 18 2006
    Audiville
    Quote Originally Posted by RoofRails View Post
    100% agreed... superchargers are special and why I've had trouble moving on from this amazing engine and car.
    2015 Audi S5 Technik
    Mythos Black Optics | DSG | Sport Diff | H&R OE Springs & 10F/15R Spacers | CR-15 | 20"x9" Black Matte Rotors | Akebono Brake Pads
    Unitronic DP 3.2 Ratio | Merc Racing Hx | Milltek Resonated Cat Back Exhaust W/Black Cerakote GT100's | Modded Airbox w\AWE Intake Tube & AFE Dry Cone Filter
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Should be interesting to see where it goes. Jose has had the Honda supercharger market cornered since Jackson Racing is no more. I’m interested to see how output vs parasitic losses on the new blower balance out. Another point is how much more it can make from the cam upgrade 034 put out on top of the upgraded blower. That said, I think it’s priced a bit high for what it is, but I get it that he’s got some development costs in it, but it’s not like he had to reinvent the wheel. Larger off the shelf charger… he had to rebuild the OEM manifold design to fit that and some new I/C bricks. I respect it, but it’s just new measurements and packaging to fit the same layout. It is clean though, so props for that…. Just don’t know if it’s $8k clean, just like I don’t think the 034 cams are $3500 worthy.
    Apr 29 2018
    Quote Originally Posted by SwankPeRFection View Post
    I have to respectfully disagree with your take that creating a new SC case isn't a big deal because the vehicle already came with one ?? There was a whole lot of 3D scanning, then 3D model test fitting and back and forth with Harrop engineer to get it to the point where he could release it for final production. He's built it to take advantage of every inch of space under the hood, which, thanks to European pedestrian crash standards, isn't much. It's the biggest aftermarket SC ever offered for this engine. He kept it under 10K, and I think that's impressive. APRs kit was 10K in 2015 and basically came with the same thing you're getting here, which is a SC.
    Apr 16 2017
    Illinois
    Quote Originally Posted by 01northernS4 View Post
    I'm sure there are plenty more cars with more stock horsepower and a similar powerband and throttle response, yeah?
    2012 S4 | DSG | Prestige | Stage 2 | 187mm Fluidampr | AWE Touring | Eurocode Sways | 034 Insert | CR-15 | Forge Charge Cooler | ECS Carbon Intake
    Oct 18 2006
    Audiville
    Quote Originally Posted by Bartlett View Post
    everything but throttle response... that's the tough one, no?
    turbos generally lag and naturally aspirated generally lack torque... maybe electric? ... but electric is missing the visceral driving engagement experience/sound/feel...
    open to good options...
    Apr 29 2018
    A well tuned NA V8 is the only thing that would be close. Something like the 4.2 in the B8 RS5, but those tend to give up a lot of easy money tuning potential.I'm thinking if Bartlett had a few good examples he would have posted them in his reply instead of acting like Alex Trebec.
    Apr 16 2017
    Illinois
    This response might be illuminating for you and there are enough examples out there for those that want to research. A Corvette ZR1, Z06, E9X M3, to name a few which were at a similar MSRP to the B8/8.5 S4/S5.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    I would love to see how they will resolve fueling on this kit for the brushless pump guys.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    what about supercharged v8s like in some jags or chevys, lol?
    Apr 29 2018
    Quote Originally Posted by fastboatster View Post
    All the stuff you guys mentioned is great but the last time I checked, this was Audizine, not Anycarzine. I just assume that when people post here, they are Audi enthusiasts and not cross shopping a German sports sedan with ZR1s, Camaro's or a British pile of hot garbage. The only thing I saw that was mentioned that was close to a S4 was the E90 M3 but the last time I checked nothing with a M3 badge has ever been priced equivalent to the corresponding Audi S model.
    Apr 29 2018
    Quote Originally Posted by Loe View Post
    I've see a kit being tested that adds a second brushless pump that is controlled by the PWM. So far its working really well for that guy and a few others, and it seems like a pretty simple solution without turning your LPFP into a giant octopus that you have to stuff back in your tank. I believe 034s solution will be a surge tank.
    Apr 23 2019
    CA
    b8 s4 is a more expensive analog to 335i, and I having both, these are pretty similar, and dare I say the 335i is more fun. I don't think that s4 compares to the m3 unless you are only talking about straight line speed.
    Apr 29 2018
    How did we get from this engines unique throttle response feeling like a NA V8 to comparing it to an Inline Turbo 6 cylinder. At least the M3 the other gentleman posted was an NA V8. All I said was that E90 M3 and it's S4 counterpart would not share the same MSRP as he was eluding to. I wasn't comparing performance between the 2 platforms. We are strictly talking about the fantastic throttle response of this engine there really isn't another vehicle in the "Audi" family to replace that feeling.
    Apr 23 2019
    CA
    well, somebody had challenged another person to bring up some examples of engines with similarly good throttle response as 3.0"T", and I decided to respond instead of them. In my view, n55 is one of these engines. it has a properly sized turbo which, along with vvt on both camshafts and variable valve lift used as throttle, makes turbo lag imperceptible. I actually don't understand how v8s came into the discussion.
    Aug 05 2013
    N/A
    Probably because the previous gen S4 was a V8 and that was kind of what Audi was looking to replace while giving a bit more power and headroom for an engine that would be used in other VW and Porsche cars. The NA wasn’t a good option for such a wide array of cross platform fitment because strung out was only going to give you old RS4 power and nothing else. They needed a smaller option forced induction solution which didn’t involve twin turboing because that would give too much power and outpace other engines/cars in their lineup and also be more involved in plumbing, etc.
    Aug 09 2015
    Sarasota, FL
    Any word on upgraded DI injectors?
    Apr 29 2018
    Nothing concrete, just 034 teasing them in their live stream.
    Aug 09 2015
    Sarasota, FL
    Gotcha. I know APR tested this on the bigger Maggy S/C with full E85. The software developer offered me a file to try it out (injectors on my own dime), but they were rather spendy injectors from another VAG family (likely why it sort of fizzled).
    If you can lean out the air/fuel a little for full E85 + keep that LPFP happy and stable, this platform has more in it. This is great that interest still continues on this platform
    Apr 29 2018
    I have heard this rumor before of cross compatible DI injectors that APR was testing. There's a calibration limitation within our ecu of 1389mg/stk which limits power output regardless of your fueling. Maybe APR had that figured out, too, but if they didn't, it would explain them giving up on the Magnuson blower.
    Aug 05 2013
    N/A
    A stand-alone ECU from Motec would be nice for our cars. M150’s are plug and play for other Audi cars and no more bullshit limits.
    Apr 29 2018
    For sure. That would solve a bunch of issues.
    Veteran Member Three Rings FromRagsToS4's Avatar
    Jan 23 2017
    Idaho
    Does anyone know what Merc's solution to injectors and fueling is? Will it be possible to run ethanol blend tunes?
    2014 S4 Premium Plus/Glacier White Metallic/6spd Manual/Sports Diff/Adaptive Damping Suspension/Black Napa Leather/19" Peelers/B&O Sound/MMI-Navi/Side Assist/Carbon Atlas Inlays
    Apr 29 2018
    That part is being worked out by 034. Mercs role in this the way i understand it was to design a TVS 1900 that fit within the engine compartment. 034 is dialing up the supporting fueling upgrades.
