Originally Posted by
texasboy21
I may have missed it, but when do the brakes squeal? All the time no matter what? Only during braking? During ALL braking for just when hot/cold?
If you have any doubts on the caliper pins, pad springs, etc. my suggestion is to take the 60 minutes to basically re-do the job and double check your work.
Brake are easily one of the top 3 things on a car that keep you alive - it's important to get it done right and with confidence.
They squeal after they heat up a bit and only when I’m not applying any pressure to the brake pedal at low speed. Goes away after I go above 25 mph or so.
I’ve already pulled them off, double checked everything, re-greased contact points and backs of pads.
The brakes are great and stop on a dime, but the squealing is so embarrassing.
I’ve reached out to EBC and waiting to hear back on what they think the issue is. Might have to back to OEM pads.
