Results 1 to 29 of 29
    Feb 19 2023
    Elliottsburg, PA
    Slip on exhaust tips
    Just bought these exhaust tips from eBay. Absolutely love them. And there's no cutting. You just knock the oem tips off and slide these new ones on.
    https://www.ebay.com/itm/13456548412...mis&media=COPY
    Sent from my moto g(7) power using Tapatalk
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Do you have any pictures of them installed?
    2019 SQ5 Prestige
    Feb 19 2023
    Elliottsburg, PA
    Quote Originally Posted by texasboy21 View Post
    2nd and 3rd pics
    Jan 08 2023
    Queens New York
    Quote Originally Posted by okie21 View Post
    2nd and 3rd pics
    Exactly, how did you remove the factory tips?
    Feb 19 2023
    Elliottsburg, PA
    Quote Originally Posted by jermar View Post
    They pull straight out. Hit it with a rubber mallet or a hammer and a piece of wood
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Thanks for the link Just ordered a set in silver!
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Feb 19 2023
    Elliottsburg, PA
    Quote Originally Posted by XMetal View Post
    Apr 01 2007
    houston texas
    Call me crazy, but arent these slip on tips kind of a big deal as there are very limited if any options for our stock oval exhaust piping?
    2019 SQ5 Prestige
    Feb 19 2023
    Elliottsburg, PA
    I'm new to Audi, so for me it's a big deal. I searched for tips, but couldn't find anything direct fit. I ended up buying a set on eBay that I was gonna have to cut the oval portion of the factory pipe to fit. I was happy to buy these and return the others.
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    Just bought a set!
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Apr 16 2021
    Washington NJ
    That's great! The stock replacements are ridiculously expensive.
    I just swapped my stock exhaust for a Milltek, otherwise I may have just done this!!
    (The Milltek, unfortunately does not sound much different than stock w/res delete).
    Nov 02 2017
    CA
    Here are the silver tips. They look fantastic! However, I'm a bit disappointed with the quality as one of the tab broke off. I had to JB Weld it back on and hopefully, it will hold since JB Weld claims to work up to 250F, which I don't think the tips will ever see those temperatures.
    Edit - Just contacted the seller and they are sending a replacement...so the JB Weld will only need to hold on just temporarily. They were super quick to response, so kudos to the seller!
    Nov 02 2017
    CA
    Quote Originally Posted by Pete Moss View Post
    Thanks for the feedback on the Milltek I guess I'm sticking with my stock w/res delete
    Feb 19 2023
    Elliottsburg, PA
    Looks good. Glad to hear the seller is taking care of you
    Sent from my motorola edge 5G UW (2021) using Tapatalk
    Jun 08 2018
    2014 Audi Q7 S-Line, 2001 VW Jetta 1.8T
    Ajax
    I like the look, the double wall gives it a bit more of a chunky look which I like.
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Ok I need these I miss the tips from my old magnaflow exhaust. How long did the shipping take to receive these?
    Feb 19 2023
    Elliottsburg, PA
    Quote Originally Posted by ralphie_43 View Post
    For me it was about 1 week, even though it estimated like 3 weeks
    Nov 02 2017
    CA
    It took about 2 weeks for me.
    Apr 16 2021
    Washington NJ
    Shocked, actually. Based on the sound clips I'd heard of the Milltek.
    It may have a bit more low end grumble, but it sounds quieter than stock to me at speed (non-resonated valved version).
    If you have other things to spend $ on, I would put them there.
    Oval tips look much better new, which is consoling...
    Jun 16 2011
    996tt
    MA
    I installed my set this passed weekend and the hardest part was knocking the stock tips off. These slipped on exceptionally easily. They look great too.
    Piece of wood and a hammer with some safety glasses and the oem tips come off.
    Align and slip the tips on. Check the clips/teeth. Only one tip had to be adjusted because of the clips got caught like in the instructions.
    Literally 15 minutes since the car was already in the air for a oil change.
    Garage:
    Apr 01 2007
    houston texas
    Quote Originally Posted by Gberg888 View Post
    Let's see some pics!
    2019 SQ5 Prestige
    Veteran Member Three Rings turbojayc's Avatar
    Sep 11 2015
    These look awesome. Any idea if they fit an 8Y; I emailed the seller to find out forsure.
    I am currently running my stock tips, painted matte black with high heat paint and a res. delete. Sounds perfect without spending an arm and a leg. Stock tips pulled right off, super easy.
    **Already heard back from the seller before even posting this question. They don't fit. If anyone has a source for 8Y tips, I'd love to know.
    2 by , on Flickr
    1 by , on Flickr
    4 by , on Flickr
    2023 S3 - Daytona Grey Pearl | H&R Sport Spring | 19" Rotiform OZR | Unitronic Stage 1+
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Apr 01 2007
    houston texas
    Quote Originally Posted by turbojayc View Post
    2 by , on Flickr
    1 by , on Flickr
    4 by , on Flickr
    Larger tips would look good, but the matte black looks great with everything else you have going on.
    2019 SQ5 Prestige
    Sep 11 2015
    Thanks, but ya. A tad beefier to fill things in would be great.
    Jun 16 2011
    996tt
    MA
    Garage:
    Apr 01 2007
    houston texas
    How have these held up? Do they wiggle and get misaligned on bumpy roads?
    2019 SQ5 Prestige
    Nov 02 2017
    CA
    So far so good for me.
    Feb 19 2023
    Elliottsburg, PA
    They've been fine. No issues
    Junior Member Two Rings A3DelRey's Avatar
    Apr 22 2023
    CA
    Plus one if anyone runs across this. I went from the Resonate Miltek to the Road+ Miltek to Non-Resonate Miltek and they're all only slightly different from each other and barely different than stock. To be fair, I wanted a quieter exhaust since I live close to people.
