Results 1 to 8 of 8
    Dec 24 2012
    Maine
    Growling or rumble noise at low speed
    Between 15 and 20 MPH there is a growling or rumbling sound coming from the drive train. Sounds like perhaps a wheel bearing but the sound goes away with speeds above 20 MPH. This is on a 2015 Allroad with 52K miles. Perhaps a suspension or bent wheel problem? Any thoughts?
    David
    2003 Allroad 2.7T
    2015 Allroad 2.0 TFSI
    2001 Porsche Boxster S
    1970 Porsche 911E
    1979 BMW 320i
    May 20 2010
    quattro rumble?
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Dec 24 2012
    Maine
    Is the B8 chassis noted for this rumble? My C5 Allroad does not have it,
    David
    2003 Allroad 2.7T
    1970 Porsche 911E
    1979 BMW 320i
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Could be the middle support bearing on the driveshaft for the rear diff. Could be many other things too. Need to know where the sound is coming from better.
    Sent from my SM-N976V using Tapatalk
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Established Member Two Rings Hagasan41's Avatar
    Sep 16 2013
    Orlando
    @DavidAR Any update on the noise? My 2015 seems like it’s developed the same noise.
    2015 A4 Quattro S-line 6MT Glacier White/Black
    Aug 06 2012
    Parker, CO
    Having replaced both front wheel bearings on my '13 allroad..... one at 176k miles and the other one at 199k miles..... the noise you're hearing sounds like the beginning of a wheel bearing going bad. get back with us in a couple of weeks. It should get a little louder and the speed in which the noise disappears should get higher.
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Sep 16 2013
    Orlando
    Quote Originally Posted by treginginco View Post
    I’ll need to investigate a bit more for sure as I only have 53k, but do have the 19” Black Optic wheels and 10mm H&R spacers all around. Perhaps the combination accelerated the wear on the wheel bearings.
    Jun 12 2013
    As long as the spacers are fitted properly, the right bolts were used, shouldn't be an issue at all. I run 10mm spacers.
    Sent from my SM-N976V using Audizine Forum mobile app
    Build Thread
