Originally Posted by
Smac770
I have a B8.0 and do not have a J250, so I can't offer any personal exploration for the necessary blocks.
https://forums.ross-tech.com/index.php?threads/20996/
It seems blocks 002 and 009 are of interest. I do know the voltage supplied to the level sensors is 5V, and the output is just a voltage divider output based on the level of the arm. Blocks 003 and 032 also seem to be of interest in the thread.
Best route would be to bring up a block and bounce on the door sill and see if values move. If they do, then you know you're looking at something reflective of the live state of the sensors. Then you can work from there to determine which corner each value represents.
That was extremely useful thanks a lot. My issue seem to give the exact same behavior, just not the same corners.
So the blocks 002 and 009 seem to all be static either without or with the fault codes triggered.
However, the interesting ones are 003 and 032.
Here are their values when starting the car :
And here they are right after the codes pop up on the dash :
Values of corner 1 and 2 are constantly changing when the car is moving, which means front ones are working normally.
So that leads me to think, the corner 4 that shows a fixed value of 50 in block 003 and ERROR in block 032 is the one broken or misconnected and that leads the corner 3 to not behave as it should and show a fixed value of 21%. Like the issue the guy is having in the link you provided.
Meaning both facing sides of either front or rear, rear in my case, should be working or else both will trigger an ERROR fault in block 032 and a fixed 50% value read in block 003.
Now to verify the state of this corner 4 level sensor, do I have to put the car on a lift and take the wheels out ? I know approximately the location of the front level sensors, but no idea about the rear ones.
