I have a 2010 A6 3.0T that is a great performer other than the cold start timing chain rattle, with a twist...
The Symptoms:
On cold start, the chain will rattle for a couple of seconds at startup which I understand is 'normal'.
After those first couple of seconds the aggressive rattle stops, but will continue with a mild rattle off and on. If I just sit there and do nothing or even gently apply some gas, it will still mildly rattle away, coming and going. I'm not sure how long it will go, at least a minute or more, I don't want to extend the time it is rattling to test it.
I even waited for the choke to cut out and RPMs to drop, but still rattlin'.
Now for the twist --- If I simply turn the ignition off and restart the car, the rattling is completely gone.
Doesn't matter if I waited 5 seconds, 10 seconds, 30 seconds, etc. As soon as I turn the ignition off and restart the car, all rattle is gone.
Ideas:
This seems like evidence that the tensioners are fine. It's almost like a sensor or switch or ECU signal etc. did not wake up and do what it is supposed to until the car is restarted. Otherwise, what is it about simply restarting the car that gets the oil where it needs to be?
If it was about building oil pressure, engine temp, etc., then it seems like just sitting there and letting it idle would fix that. For me, sitting there longer at idle does nothing. The trick is just turning off the car and restarting.
Once I have completed the start / restart ritual, rattle doesn't occur again the rest of the day (so far), even if the car has been sitting for 8 hours or more.
I know I've read of others on here who changed tensioners and then the problem returns not long after, indicating that the root cause likely never was the tensioners to begin with.
Has anyone figured out a sensor or other part of the system that may really be the root cause?
Appreciate any input, thanks!
