Results 1 to 19 of 19
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Installed Xtrons headunit but....
    I'm happy with the outcome everything works exept Bluetooth music or my Aux in cord connected to phone. It used to work prior to install.. No soundscon speskers when i go on media and aux in. Everything on unit is connected en functioning. What could be the cause of this. And yes fm and Am work fine. 20230610_224552.jpg
    Sent from my SM-S916U using Audizine Forum mobile app
    Ivan
    Jul 16 2018
    Atlanta
    Bluetooth music. What device is the phone Bluetooth connected to? That aftermarket device or the car? Or a Bluetooth device on the AMI port? What is music audio output set to on the phone (I'm assuming it can be controlled as to what output device it routes). The device is just a screen; the AMI port is still connected to the radio head unit (unless the aftermarket wiring changed that). You'd need to see where the AMI port pins are actually going in the new wiring. The smart thing would be they route to the device, then the device routes to the AMI input so you can just set the radio to External Audio and leave it and hear everything. But it could well be the device doesn't do, but still steals the AMI pins on the radio, meaning the AMI port is now unconnected.
    Too hard to speculate without knowing what all happened to the wiring configuration.
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    A close examination of the "ISO Wiring Harness" would help tease out how the device integrates into the car for audio out and CAN bus, for example. But they also mention an "Audio Extension Cable", which looks to be how the Xtrons device gets its (analog) audio out to the MMI main unit. A published wiring diagram would be helpful here, too. --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Jun 29 2018
    Orlando
    Can I ask why you chose this unit opposed to another like rsnav?
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    Aug 19 2013
    Miami
    Quote Originally Posted by bastafari View Post
    I wanted an oem inside unit not en external unit that looks very aftermarket plus in colombia thives will break the window to steal it. So an internal unit is mot favorable
    Ivan
    Jul 16 2018
    Atlanta
    RSNAV has always had an 8.8" factory look unit also; they are replacing it now with 8.9":
    https://rsnav.com/collections/s3-and...a5-s5-q5-sq5-1
    I think the factory look is the way I'd go, though it'll mean being a few more inches out of reach.
    In either case, with Concert/Symphony, it seems both products integrate the audio output only via an analog out that must be routed into the factory system input selection.
    Aug 19 2013
    Miami
    Guys so upon further inspection my guy installer did not use this cables. Both of them but my car doesn't have that Audi music interface to plug in that cable but it does have Aux In. This is what he didnt use. Is he suppose to use this extension for Aux? Screenshot_20230612_042702_eBay.jpgScreenshot_20230612_043036_eBay.jpg
    Ivan
    Aug 19 2013
    Miami
    Quote Originally Posted by Smac770 View Post
    I don't have or see an Ami port on the car. Only Aux in brother....
    Ivan
    Aug 19 2013
    Miami
    No Ami port in the car so i'n basically focked? Ordered an android unit and won't have sound 20230612_050130.jpg20230612_050133.jpg
    Ivan
    Aug 31 2014
    NW OH USA
    Quote Originally Posted by dalmation53 View Post
    Your Symphony radio has AUX-IN on the FAKRA QuadLock connector to the radio, which runs to the port/jack in the armrest box (through the car wiring harness).
    It seems to me a better way to do this (than running their "audio extension cable to the jack") is to go directly from the add-on box to the QuadLock connector. Check the wiring diagrams for specific pins here (I believe it's on the green terminal block). --g
    Jul 16 2018
    Atlanta
    R199 AMI and R199 AUX will both have analog audio lines going into Concert/Symphony on the same pins. The R199 AMI device for CAN additionally has connection to the Infotainment CAN bus, that's all. I don't know if there's any data transmitted over CAN, or if it's only control. For example, if you have a USB drive with music files, is the parsing of the file system and the conversion to analog audio actually occurring in the AMI device, producing an analog audio output to the radio? It would seem to be most likely so. Rather than transmitting USB digital data stream over CAN to the Concert/Symphony for processing, decoding, and conversion.
    The new RSNAV series 4 apparently now supports not needing to connect its audio output to the AMI/AUX port to feed back into the factory system for playback. I'm not sure by what means its dumping the data directly to the J794; it's not on the MOST ring. But this is only for MMI 3G. MMI 2G and Concert still need the traditional external 2-ch analog audio path.
    The Xtron unit appears to be the same as the RSNAV in this regard. You're going to have to connect the Xtron analog audio output to the analog AUX input port, be it to an AUX R199, or to an AMI R199 with AMI AUX cable.
    Aug 31 2014
    NW OH USA
    My guess here is that the aux-in port in the center console box is wired *directly* to green terminal block T12s in the FAKRA QuadLock connector (T12s/1 is analog line-in L, 2 is ground, 7 is R). I don't understand why these Chinese vendors just don't add this to their FAKRA QuadLock wiring harness adapters if the after-market display boxes are intended to be used with Concert/Symphony radios.
    If the OP finds his Xtrons device to be working to his satisfaction, he should consider connecting the analog line audio out from the Xtrons box to terminal block T12s, directly. --g
    Aug 19 2013
    Miami
    Quote Originally Posted by DrGER View Post
    My guess here is that the aux-in port in the center console box is wired *directly* to green terminal block T12s in the FAKRA QuadLock connector (T12s/1 is analog line-in L, 2 is ground, 7 is R). I don't understand why these Chinese vendors just add this to their wiring harness adapters if the after-market display boxes are intended to be used with Concert/Symphony radios.
    So i have to remove the screen again and plug my Aux into the wiring harness that it came with?
    Ivan
    Jul 16 2018
    Atlanta
    You're skipping the step of testing if that's even worth doing. Just plug the thing into your existing AUX port and see what happens. Did you ask the installer why they didn't connect the audio?
    Aug 19 2013
    Miami
    Smac i'm conffused. What do you want me to plug in into my Aux port?
    Ivan
    Jul 16 2018
    Atlanta
    They seem to have in interesting direct TPMS high presentation and direct TPMS sensor system, both external or internal. Don't think RSNAV has that functionality.
    https://xtrons.com/tyre-pressure-mon...-system-tpms08
    https://xtrons.com/tyre-pressure-mon...-system-tpms07
    https://xtrons.com/community/index.p...-android-unit/
    I am very unimpressed with their site from a support/documentation perspective. They have nothing, absolutely nothing, for the QEA units.
    The $400 price on their website is not enticing, but the near $300 price on their aliexpress store is a bit hard to ignore.
    So can't advise you how the thing is suppose to connect audio wise.
    Jul 16 2018
    Atlanta
    https://cdn.shopify.com/s/files/1/19...f?v=1662349394
    Note page 2, it showing the analog audio connection circled with a. You need to find that and run that to the AUX input.
    DrGER's point is why do they bother with that at all? Why not just run the bare wires (with crimp terminals) to the quad block go-between on the Concert unit side plug. It would seem to make for a cleaner installation.
    Also note the other point on that page, checking the pins and make sure everything looks good.
    Actually, start there. If you plug anything into your AUX port and select Media-AUX, do you get playback? Is the wiring still good?
    Aug 19 2013
    Miami
    So the one circled in blue is the one that i need to run it all the way to my aux port? Thats why the cable is so long? Hmm i think he jammed it in there somewhere i will have him tomorrow remove the screeb again and i will update tomorrow. Screenshot_20230613_031152_Samsung%20Notes.jpg
    Ivan
    Jul 16 2018
    Atlanta
    I can't find anything regarding legitimate installation documentation, or even references, for the Xtrons QEA units. Straight up nothing, not even from Xtrons themselves. So I have no idea what's behind the screen unit. But it's not going to be anything revolutionary. It's going to be generally the same as every single other Android tablet replacement solution for Audi B8. How did the installer have any clue what to do with this thing?
