I doubt the B9 draws any less power than my B8 at base minimum, which is 10A just sitting there with everything disabled I can (doors closed, climate system off, DRLs off, audio muted, etc).
AZ a.co links suck; the redirect just keeps ending at superoffers.com. The CTEK 20A unit (CS Free) is $300. I assume this is the one linked since 034 says 20A+ and CTEK. The CTEK 25A is $500.
The Clore sounds likes a good unit, full featured charger with power supply mode up to 20A. But I find this statement in the manual odd: "Also, this operational mode is intended for use in a wide variety of repair applications, but is not intended for use when flash reprogramming vehicle modules – such reprogramming requires amperages great than the output of this charger." Appears power supply mode is a fixed target of 14.1V. Which matches up to Clore's document for flashing voltage:
https://cloreautomotive.com/wp-conte...-Charger-3.pdf Of course they have a unit they recommend for flash activities, PL6100, at quite a few hundred dollars, and requires a 20A 120V circuit.
Seems brands known for power supplies to support vehicles during flashing/programming include Midtronics, IOTA, Fronius, Ateq, Schumacher. And seems 50A is the starting point for a flash supporting power supply. Probably why Clore's statement. But damn, you're at $300 and up for that kind of supply. Midtronics MSP-070 starting at $800 and up.
https://mhhauto.com/Thread-WHICH-BAT...-OF-MIDTRONICS
Needing 70-100A for a programming event sounds nuts to me. Sounds like 20A seems reasonable. It would be interesting to know what specs the dealerships use when doing ECU, TCU, and MMI updates. Some of that MMI stuff can take over an hour.
The one on the audi.snapon.com is a Schumacher, 65A,
https://audi.snapon.com/SpecialTools...temId=66210163
