Results 1 to 8 of 8
    Apr 16 2015
    SC
    C7 S6 No Communication With TCM
    I recently changed the Transmission Temperature Sensor on my 2013 S6, and when I plugged the sensor back in and went to start the car it would not start. It flashed a TPMS Malfunction Light and Parking Brake Malfunction light. It also flashed a message saying to shift the car into neutral or park to start the car.
    I then scanned it with VCDS, and I cannot get it to connect to the Transmission Module at all. I tried a few other modules and several others won't connect either. Below are the system warnings I'm getting.
    At this point I am completely lost and have no clue what to do. I can't even limp it to a shop or dealership because the car won't start or allow it to shift into Neutral or anything. Does anybody have any ideas?
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Cannot be reached 0100
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    28-HVAC, Rear -- Status: Malfunction 0010
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    BA-Motor Mounts -- Status: Malfunction 0010
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    What sensor exactly did you replace? Was it Temperature Sensor 2 - G754 right in the like center tail of the trans?
    I don't recall much other wiring in that area, but still I would re-check wiring.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Apr 16 2015
    SC
    Quote Originally Posted by gk1 View Post
    Correct, it was the sensor that doubles as a drain plug. Literally didn't touch anything else under the car except for that sensor. Is it possible that a bad connection at that sensor can cause the TCM to go haywire?
    Aug 06 2014
    NJ->CO
    Sadly anything is possible.
    Are all the other malfunctions listed just refencing that they cannot communicate with the TCM or is there any more valuable info there?
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Apr 16 2015
    SC
    I couldn't find any relevant info when scanning the various modules unfortunately. Seems highly unlikely that many modules are all failing at once though.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by ForceFed4g63 View Post
    Voltage variation (e.g., gradually failing battery) may trigger multiple errors. Would a (false) high temp reading from the sensor cause this behavior?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Apr 16 2015
    SC
    Quote Originally Posted by Alabama View Post
    I thought of the battery as well, but it's a newer battery (less than a year), and I kept the battery on a trickle charger for the few days it was on jack stands.
    I decided to disconnect the battery for a day to see if that helps, I've heard it can help clear things. If that doesn't work I will get underneath the car again (huge pain as I don't have a lift), and start checking connections again.
    Apr 16 2015
    SC
    In case anyone was wondering or following along. I ended up taking out and examining the transmission connector/plug/harness, and there was coolant in there with some pretty serious corrosion. Seems to be a fairly common issue where the coolant solenoid/valve leaks. I ordered a new connector off ebay, and will be replacing all the connectors/plugs, and the valve as well. I'm just hoping the leak hasn't affected the TCM itself or the mechatronic unit. I guess we'll find out!
