Results 1 to 2 of 2
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Rear subframe rust 2012 A6
    Hey all,
    Wanted to get opinions from everyone here. Picked up this A6 a little over a month ago and getting an EVAP very small leak, so I was in the process of checking the NVLD and charcoal canister when I noticed this rust on my rear subframe. It looks mostly surface and when hitting the subframe it does sound solid, but seems like excessive rust. Is this something I can wire wheel off, use a rust penetrant for the tough-to-reach spots, then use something like Rustoleum/PoR-15?
    Thanks all
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by MyDimeIsUp View Post
    Move to where there's less road salt in the winter?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
