Results 1 to 6 of 6
    Junior Member Two Rings seaniscoolikeA4's Avatar
    Feb 26 2018
    Endicott, NY
    Parking Brake Engagement Squeal
    My parking brake is squealing quite loud when engaged. Any remedy suggestions short of replacing parts? They're $$$. Thanks
    Sent from my SM-S918U using Audizine Forum mobile app
    2014 Ibis White A4 S Line 6MT Quattro
    APR Stage 1 | CR-15 Front Strut Brace | ECS Luft-Technik FMIC | Hard Charge Pipe | ECS Turbo Muffler Delete | AEM Cold Air Intake | 034 Motorsport Trans Mount Insert | NGK Iridium Spark Plugs | Red Coil Packs
    South Bend Stage 2 Daily Clutch | South Bend Single Mass Lightweight Flywheel | ECS Stainless Steel Clutch Line | RS4 Honeycomb Grille | BFG DV+ | ECS Weighted Knob
    Jun 01 2023
    Scotland
    Sometimes all they need are stripped down and lubed, had that on my previous Passat with an EPB. Thought is was going to need new motors but just needed a strip, clean and lube.
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Quote Originally Posted by madrab View Post
    Good to know. My parking brake has gotten a bit noisy over the past six months or so. After 95k miles, rears are getting a bit low, so I’ll have this looked at when its time for brakes.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Aug 06 2012
    Parker, CO
    My parking brake has squealed like a horny bird since I've owned it. It's now been 11-years and nearly 200,000 miles and that damn thing is as horny/noisy as ever. :)
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Established Member Two Rings kingVR's Avatar
    May 23 2011
    Ontario, Canada
    My S5 epb has started screeching about a year ago. Mechanic says it's a sealed unit, nothing to lube. Maybe just deferring teardown until the next brake job.
    Good to know it's not causing any harm. I lived through both brakes seizing on the B7 S4 ($500 a pop)!
    Sent from my BBD100-2 using Tapatalk
    Sep 03 2014
    2014 Audi Q7 Premium Plus, 2014 Audi A4 2.0T Quattro S-Line
    Ellicott City, MD
    My 2014 A4 S-Line E-brakes have been squealing for as long as I remember. As long as the E-brake still works I'm not concerned about it, but it's nice to hear that I'm not the only one experiencing it.
