Hello, I have a 2013 Audi S5 where the MMI and radio just stopped functioning. Tried resetting the unit, disconnecting and reconnecting the battery, checked all fuses, all to no avail. Bought the Ross-Tech HEX-V2 and ran a clean optical bus diagnostic. Performed a full scan (for the first time on this vehicle) and did receive some errors where the radio, sound system, and 5F cannot be reached. Checked for water damage and the wiring of the components in the loop and didn't discover anything. Ordered fiber optic loop to help verify components. Any help or clues would greatly be appreciated. Full scan posted below. Thank you.
Wednesday,24,May,2023,13:42:38:65290
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUGGAFRXDA016970 License Plate:
Chassis Type: FR-AU48 (8R0)
Scan: 01 03 05 06 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56 5F
6C A9
VIN: WAUGGAFRXDA016970 Mileage: 98720km-61341miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: Sporadic communication error 1000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0002
Revision: --H07--- CVN: 90188024
Coding: 1A190034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 38293A6D42DC7B6AF7B-806C
VINID: 9D19575D15A2A1444004624700F48AF902
1 Fault Found:
15789 - Engine Speed Sensor (G28)
P0321 00 [101] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 91826 km
Date: 2020.08.14
Time: 16:08:08
Engine RPM: 267.00 /min
Normed load value: 0.0 %
Vehicle speed: 4 km/h
Coolant temperature: 98 °C
Intake air temperature: 60 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.288 V
Unlearning counter according OBD: 40
Engine speed: actual: 0 /min
Engine: operating status: ES
ENVD_CRK: 0
Vehicle speed: actual: 4 km/h
N_TOOTH_32_DIAG_CRK_SIG_LOSS: 512 /min
N_CAM_32_DIAG_CRK_SIG_LOSS: 768 /min
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 281D1A
Shop #: WSC 06325 000 00000
VCID: 04519E9D4E14EF8A2B3-8050
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H11 0621
Revision: 00002001
Coding: 0F804000000000000000
VCID: 015F97895106FAA2005-8054
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2312000143029014
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 3
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.17
Time: 16:16:23
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000034146123
Coding: 00037025002C00000000
VCID: 45D7439905AE16827CD-8010
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.17
Time: 16:16:23
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Component: KLIMA 3 ZONEN H04 0121
Revision: C1000000 Serial number: 01140720120527
Coding: 6602228000
VCID: 392F3F6979566262085-806C
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000447474201
Coding: 26000011803CAFE0240040C300003D0D0F9C9388A209022100 0008000000030100000030000000
Shop #: WSC 06325 123 12345
VCID: 78A9FA6D02DCBB6A37B-802C
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110712 H15 0080
Serial number: SWF12070110046
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20408360
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000207120873
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R29DN02
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 8E188936000000000001
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.17
Time: 16:16:23
01800 - Light Switch (E1)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.18
Time: 08:46:54
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Component: AirbagVW-AU10 H45 0610
Serial number: 003KJD90F8YZ Dataset Number: 8T0909602N 0004
Coding: 303343334830303030304A55304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4ACD70A52C30F9FA91F-801E
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R1200009GDX
Crash sensor for side airbag: driver side:
Serial number: 6334MSME706426233
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME6E106812C
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME321A0764A
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME2E1C3A52R
Crash sensor for front airbag: driver side:
Serial number: 63732SME6C1C236EC
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME6C1C125EA
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20120716001438
Coding: 000016
VCID: 51FF67C9C1E6CA22D05-8004
Component: E221 - MFL H03 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 983 P HW: 8T0 920 983 P
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RAU46197D
Coding: 8BBD01008301D705020000
VCID: 4BC375A123CAE0F2AA9-801E
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 H HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0051
Revision: 1Y050025 Serial number: 2541Y126210402
Coding: 80C303FF00
VCID: 44D15E9D0E942F8A6B3-8010
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 2195917501
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.17
Time: 16:32:41
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.80 V
Count: 10
Bin. Bits: 00000
Time: 25.40 s
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H13 0100
Serial number: 000407120001032 Dataset Number: 8T0909104C 0026
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F3B0131B792BCD2A61-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000034154361
Coding: 001B7B25002C00000000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.17
Time: 16:16:23
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13224E00120102
VCID: 56F594D5E808AD1A057-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0025681893 Dataset Number: 8T0909852H 0017
Coding: 100000010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 34310E5D5EB49F0ADB3-8060
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0179865591
Coding: 0106069A00FA404580B0003200000000
Shop #: WSC 06324 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000545200
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.17
Time: 16:16:23
00457 - Central Electronics Control Module / BCM (J519)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.18
Time: 08:47:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 98724 km
Time Indication: 0
Date: 2023.05.18
Time: 08:49:09
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55F793D9F50EA6020CD-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001146856
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H07--- Serial number: 525PA8-J25901U
Coding: 1000008
VCID: 38293A6D4E5C7B6AF7B-806C
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 120623201531
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
VCID: 72BDC8456420D13A09F-8026
End----------(Elapsed Time: 01:28, VBatt start/end: 14.3V/14.2V)-----------
