Results 1 to 9 of 9
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    WTB: Audi C5 A6 (2004) RNS-E (US Version) with all Hardware and Wiring
    Wanted to see if anyone was parting out with their US version RNS-E for those that have upgraded from the Symphony II. Before I go and source everything out, maybe I could take this off someone's hands who are looking/thinking about selling their setup or parting out. I'm looking for all hardware and wiring that I would need for a plug and play install. Thanks.
    -P
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Veteran Member Four Rings ChicagosPhantom's Avatar
    Aug 28 2013
    02 Nemo S6 (stolen) / 03 Silver A6 2.7T K04 01E / 03 Daytona RS6 / 04 Dolphin A6 2.7T 01E / 02 Silve
    Chicago IL
    Quote Originally Posted by Deckdout2 View Post
    -P
    I have Gen 2 ready to go.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    That's what you need, the Gen2. I had the old one and upgraded years ago. Better screen, takes bigger SD cards. faster processor. And while you're doing the install you can removed the Onstart module, tap into the GPS antenna directly and use the Onstar microphone in the Sunroof control panel for your Bluetooth. I may have all of the install instructions if you need them.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Definitely would go for newer version of RNS-e. For best compatibility flash with https://rnse.pcbbc.co.uk/ firmware and transfer maps to fast good quality SD card.
    Junior Member One Ring
    Apr 09 2018
    Idaho
    Just a kudos to ChicagosPhantom who fixed and cleaned up an older RNSe unit I sent to him a little while back. Great work, so this unit here would probably be the way to go
    Dec 04 2012
    Arlington VA
    was he able to do anything about peeling soft touch paint on the face panel? I got A3 second gen and put gen1 face on it, everything works, but peeling paint does not look too good.
    Jan 10 2008
    Roy, WA
    I knew he was famous/infamous for his C5 Headlight repair and upgrades. This is the first I had seen that he does RNS-E's too. Man of many talents.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Aug 28 2013
    Chicago IL
    Quote Originally Posted by strlgag View Post
    Glad I could help...
    Aug 28 2013
    Chicago IL
    Quote Originally Posted by hahnmgh63 View Post
    Anything four rings C5 related, mostly, it's a disease!
