Results 1 to 13 of 13
    Junior Member One Ring
    Aug 09 2022
    New York
    Low Tire Pressure Light, Tire Pressure is Fine
    Hello all, As the title states, my tire pressure light keeps coming on yet my tire pressure is fine. I know Audi does a weird calculation to find the "tire pressure" based on the wheel speed sensor readings. I would suspect I have a faulty/bad wheel speed sensor but my speedo is working fine.
    Anyone run into this? What was your issue? Alignment issues? Balance issues? My car seems to drive straight, tires seem to be wearing evenly from what I can tell and, tires seem to be balanced maybe a very slight imbalance
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Quote Originally Posted by Gerthex View Post
    I'm assuming you saved the pressures in the mmi?
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Could be a bad TPMS sensor on that tire. Like ^, did you save?
    Sent from my SM-N976V using Audizine Forum mobile app
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Apr 01 2021
    Quote Originally Posted by Allowencer View Post
    There are no tpms sensors
    Aug 09 2022
    New York
    Quote Originally Posted by apeck240 View Post
    Yes I have saved pressures after adjusting. The light comes on almost immediately after I start driving, occasionally it may take up to a day to pop back up.
    Jun 12 2013
    Sorry? There isn't a sensor in the tire/valve stem?
    Sent from my SM-N976V using Tapatalk
    Build Thread
    Aug 09 2022
    New York
    Nope! Thats how most car manufacturers do it but not Audi. They use the wheel speed sensor to calculate the change in tire diameter which would have a direct correlation to tire pressure. Once below X tire diameter, the TPMS light kicks on. To me this is like the definition of German engineering lol. It is overly complicated but actually makes sense and also less parts and hopefully less cost to the consumer.
    Jun 12 2013
    I could swear when the shop has changed my tires I saw the modules. I have 2 sets of wheels, my summers have them and my winters don't. I don't have monitoring when I have my winter tires on the car. Unsure if that changed in later years maybe? My car is an early 2010
    Build Thread
    Jul 16 2018
    Atlanta
    Direct TPMS is on the MY09. MY10 initiated indirect TPMS gen2, which was developed enough by that time such that regulations would allow it. And you can be sure VAG was all over that to cut costs. And Canada didn't get TPMS at all anyway because it's not required there. That Canadian MY10 must have been retrofit with the J502 and wheel sensors.
    Jun 12 2013
    I have a US car. I might be a MY09 then (early). Interesting.
    Could indirect be retrofitted?
    Build Thread
    Jul 16 2018
    Atlanta
    Indirect requires a different ABS/ESP module with additional computing resources vs. direct.
    Model year when discussing the car features is always clearly denoted by the VIN. Either the 10th character is a 9 or an A. https://www.fcarusa.com/TechSupport/KB/vin-year-code
    May 07 2017
    The Netherlands
    I had this with also indirect pressure alarm.
    Aleared to be hanging rear brake, brakeklaw had to be replaced.
    So clear the message, and if it comes back after 10 minutes driving.
    Park direct safely, and feel the rimms.
    If at one (mostly rear) you burn your fingers, thsts the hanging brake.
    Explanation is that the heat produced, highens the tirepressure, wich gives a larger rolling circumference, so ABS detects difference in rotationspeed, and explainst that as low pressure on the other side.
    So still usefull message, but the other way around.
    Aug 09 2022
    New York
    Quote Originally Posted by jadatis View Post
    This is exactly what I was looking for! I think this is my issue honestly. I have a manual a4 and ever since i changed my pads it doesnt seem like the car rolls back on hills in neutral as much as it used to be making me think the pad is getting hung up a bit. I can feel some pulsating from the brakes for a few months now, very minor. I have been planning on changing brakes once it got a bit warmer. I am expecting this to my issue. thanks a bunch!
