Results 1 to 12 of 12
    Senior Member Two Rings sjlversurfer's Avatar
    Jun 17 2004
    2019 S5 1998 A4 1967 Beetle
    Laguna Niguel, CA
    RS Style Oval Exhaust Tips on B9 S5?
    Is there an RS style exhaust tip for B9 S5 sportback? Thinking the rear valance would also need to be changed?
    I've not seen anything, and since the stock tips are welded on, I'm not sure there is an option, but wanted to check with the community.
    The stock chrome tips just get charred so quickly. I've heard of black tips and Cerakote, but would also like a little more style than the stock tips. My car supposedly has black optics package, so not sure why the tips are chrome. Not looking to replace the exhaust.
    Show me your exhaust tips!
    TIA
    Veteran Member Three Rings XSWG's Avatar
    Jun 07 2016
    2018 BMW M4, 2018 Audi SQ5, 2016 BMW M6, 2017 Triumph Daytona 675R
    ATLANTA
    So you'd want to go from quad tips to dual. You can buy the tips AWE and Milltek have the RS5 exhaust for example with clamp on tips so you can order from them. Just tell them they were damaged and you need replacements I suppose. AWE doesn't sell them separately if I remember correctly.
    You'd just cut off the stock tips and have the new ones welded on. I did the same on my S4 when I had a custom stainless exhaust but I prefer quad tips. I've also seen the carbon fiber Akrapovic exhaust tips which looks nice but there are a ton of knockoffs.
    Sent from my SM-S908U1 using Tapatalk
    2019 S4 Prestige Satin Flip Ghost Wrap w Magma Interior — Black Optics — 034 Stage 3- TTE810
    Mods
    TTE810 + CARBNLABS DP + FBO + Custom Exhaust
    034 parts + Every unnecessary mod because I lack self control
    Other Toys:
    G16 BMW M850 & F82 BMW M4 - 2018 SQ5 & 2018 Range Rover Velar P400 - 2017 Triumph Daytona 675R
    Feb 02 2017
    Beaverton, OR
    I had a shop paint mine black along with some other pieces(rear wing, diffuser, side blades, front side pieces) since mine is a 2018 and didn't have the black optics package. It looks so much better with the black accents.
    Senior Member Three Rings Zombie5150's Avatar
    Apr 18 2021
    2022 Audi RS5
    Boerne, TX
    Quote Originally Posted by chip_ View Post
    Excellent, nice and clean. Looks like it came from the factory that way.
    2022 Audi RS5 Sportback - Mythos Black
    Dynamic, Dynamic +, Dynamic Steering, RS Design, RS Driver Assist, Side Assist, Black Optic Carbon, Navigation, Rear Air bags, Black Rings & Emblems.
    Vossen HF-3/Michelin PS4S, Full Xpel PPF, Fusion Ceramic, Ceramic Tint, JL Sub/Kicker Amp, FitCam X, Tuxmat Cargo Liner, Emblem Debadge (F/R), MMI screen protector, MH62 IPOD Cradle, additional puddle lights.
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by ahvier View Post
    TIA
    Search for a build thread in the B9 S4 forum by @BrockDM . He had RS5 exhaust tips on his S4 and made a guide on the install.
    '18 S4 Prestige; all packages
    Established Member Two Rings V6Quatt's Avatar
    Dec 16 2011
    England
    looks real good
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Quote Originally Posted by SHCKR View Post
    #554
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Next up on the mod list, <b>Milltek RS Road+ Mufflers</b>!<br />
    <br />
    This one has been a long journey.. What started as me just wanting to change the ugly pitted stock exhaust tips ended with what will probably be a full custom exhaust lol. <br />
    <br />
    My original plan was to keep the stock exhaust exactly how it was since I really like how it sounds paired with my Milltek cat delete and just change the tips. Of course I couldn't just settle on getting regular 3.5-4" quad tips and be done with it. I came up with the idea to run Milltek RS oval tips from the RS4/RS5. I always loved how these tips looked and the presence they make. I get it's not for everyone and some will gripe about "oh you're running Milltek tips without a Milltek exhaust", yada yada. Well I wanted to be different and do something that you don't see all the time. Sooo that landed me on the dual inlet RS oval tips from Milltek. I reached out to Mops and Martin over at Nemesis to see if they could source me a set of tips and what luck because Martin had a set left over from his RS5 that he did not need. It was meant to be! lmao. He hooked me up with a great price and the journey begins.<br />
    <br />
    I ordered adapters, clamps, basically everything that I thought I needed in order to make these work. I would cut the stock tips off and boom slide the new ones on. HA HA HA. Did not go as planned. The spacing from the muffler outlet and tip inlet wasn't the same and wouldn't line up. So after pondering a few ideas, I took it to a local shop that basically yeah we don't want to mess with it. It doesn't look like it's going to work. Well F! <br />
    <br />
    I reached back out to Martin and lo and behold, he had a set of Milltek Road+ mufflers from his RS5 that he doesn't need either. A massive thanks to him for hooking me up and sourcing this whole project. <br />
    <br />
    I received the mufflers, got in contact with a new shop (big shout out to @Trexturk on IG) and got them all mounted up. He did an outstanding job lining everything up and tucking the massive mufflers up under the car perfectly. I couldn't be happier with how they look. Aggressive but not out of place.<br />
    <br />
    Due to the mufflers being Road+ they are packed incredibly tight with resonating material so my exhaust is significantly more quiet now which I'm not a fan of. It didn't really dawn on me at first but makes sense now since the stock mufflers are so small. Next up I'll likely either get a 034 X Pipe and see if that helps bring it back to life or see if Tan can fab up something with the stock mufflers and make the RS tips slide onto that and just sell the Milltek mufflers to someone else since they line up for an S4 now. We'll see.<br />
    <br />
    Overall I'm incredibly happy with the new look. It may not be for some people I didn't want to be like everyone else.<br />
    <br />
    Enjoy!<br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    Aug 13 2008
    Reston, VA
    Quote Originally Posted by sjlversurfer View Post
    TIA
    no one is ever happy
    i have oval tips on my RS5 and i much prefer the quad tips of the S5 :)
    Jun 17 2004
    Laguna Niguel, CA
    Quote Originally Posted by kmarei View Post
    after seeing the replies, going to dual tips looks like quite a bit of work, so I'm going to stick with the stock quad tips and either paint them or cerakote them. Thanks for all the feedback!
    AKA: ahvier
    Junior Member Two Rings
    Aug 30 2023
    #554
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    Enjoy!<br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    if by any chance you are selling those tips pls dm me xD
    Established Member Two Rings STi from DSM's Avatar
    Sep 15 2022
    Minnesota
    Those tips are really only good for the Milltek setup. I know for the S5 if you want to switch you have to switch bumpers as well.
    2022 BMW M850i (Twilight Purple - Individual color)
    2019 Audi RS5 Sportback (Navarra Blue) SOLD
    2021 Audi S4 - Quantum Gray - SOLD
    2018 BMW M5 (Singapore Gray) SOLD
    2019 Audi RS5 (Mythos Black) SOLD
    2020 BMW X3M Competition - SOLD
    2019 Audi RS3 (Mythos Black) - SOLD
    2018 Subaru STi Type RA (Black) (#391/500) - SOLD
    2018 Audi RS3 (Nardo Gray) - SOLD
    Aug 30 2023
    Quote Originally Posted by STi from DSM View Post
    I have a 2019 S4 with an ecs cat back. I would just pray it lines up :(
