I’ve got a 2016 A6 3.0T CREC running a stage 1 E85 IE tune. After switching to E85 for the summer I immediately had spark blowout at high RPM. I’m used to turbo cars so I knew I needed to change plugs and potentially regap. When I pulled the plugs out I found Cylinder 6 to be partly melted at the tip. I assumed it was due to age since I had not changed them in 30k. Swapped in a set of BKR6EIX since I didn’t have any 8’s handy and hoped this would fix it. However after some VERY light driving(compared to normal) I melted another plug this time on Cylinder 2. I had a dead miss and the whole tip of the plug was missing. Luckily the ceramic stayed in place. Somehow the engine survived both of these failures until yesterday. After the 6’s melted I put in some BKR9EIX, 4 steps colder than stock, and 1 step colder than recommended by IE. This alleviated the issue almost completely. You could tell the car was missing some power but was still plenty peppy to daily until I sourced a good engine. But yesterday I melted one of the BKR9EIX’s this time on Cylinder 1.
This marks 3 different cylinders to do this. I knew my engine was hurting after the initial spark plug change as I did a comp check and everything was at ~120. However, in my Honda days even when I blew my tubo’s Bseries it ran and never melted plugs even when all 4 cylinders hit low 80’s in compression. So I wouldn’t expect to be blowing plugs out simply due to low comp. If it were one cylinder I’d say injector(s) but since it’s on both banks I’m not sure what to lean towards being the cause of this. I’m very happy with my IE tune but when emailed they basically told me it’s all my fault since I didn’t have the “right” plugs in. Which although partially true now that I’ve melted 9’s I’m getting suspicious of the root cause. E85 at the station I pull from rarely dips below E70 although admittedly I did not test before the most recent fill-up(yes stupid I’m aware) however the first two sets blew when E content was tested to be at E78-E80
I’m wondering if anyone else has had similar issues to what I’m having? Any non-CREC owners had issues like this? All I’ve been able to find is new gen 1.8T that are tuned destroying plugs in a similar fashion..
Also I would love to post picture but I’m new posting on forums (this is my first post!) and I’m not sure what site to use to upload them. If anyone can point me in the right direction to figure that out I will upload some pictures!
