Results 1 to 7 of 7
    Nov 22 2005
    socal
    Drive system malfunction and red/white circle
    Anyone experience this, 2018 Q7 prestige. At stop light got the drive system malfunction warning and the engine shutoff. Had to turn car off and back on. Once back on the traffic sign notification area which would should the speed limit no longer showed the speed limit and instead showed a 25 with a red/white circle around it. I'm in USA and normally it would show the white MPH sign.
    Car has done th drive malfunction engine shutoff 3x this week.
    Senior Member Three Rings angrycatmeow's Avatar
    Jan 22 2022
    FL, US
    That's the European speed limit sign. My 17 has done that before once. I thought it was funny.
    As far as the drive system malfunction, you gotta scan it.
    Sent from my Samsung smart air fryer
    Nov 22 2005
    socal
    i thought that might be a euro speed limit sign. strange that it only happens after the drive system malfunction, wonder how they are related.
    i am going to scan the car today when i get some time.
    Nov 22 2005
    socal
    OBDeleven data log
    Date: 2023-05-01 10:31
    VIN: WA1VAAF70JD028401
    Car: Audi Q7
    Year: 2018
    Body type: SUV
    Engine: CREC
    Mileage: 92423 KM
    01 Engine
    System description: 3.0l V6 TFSI
    Software number: 4M0907551A
    Software version: 0005
    Hardware number: 06E907425
    Hardware version: H10
    ODX name: EV_ECM30TFS0214M0907551A
    ODX version: 001007
    Long coding: 2A2A00320576010D74280000000000000000000000000000
    Trouble codes:
    P10A300 - Actuation regulating flap for intake air Open circuit
    Intermittent
    Date: 2023-04-30 18:39:28
    Mileage: 92401 km
    Priority: 2
    Malfunction frequency counter: 2
    Unlearning counter: 255
    Engine speed: 0.00 1/min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 91 °C
    Intake air temperature: 34 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 12.695 V
    Dynamic environmental data: 2096273953003804000046E10000157A0000150C0ABD46E200 1546E300
    U112300 - Databus error value received
    Intermittent
    02 Transmission
    System description: 0D5 30TSIUSA
    Software number: 4M0927158L
    Software version: 1006
    Hardware number: 0D5927156H
    Hardware version: H05
    ODX name: EV_TCMALX52011
    ODX version: 002010
    Long coding: 100000
    Trouble codes:
    No trouble codes found
    03 Brakes
    System description: ESP9 Premium
    Software number: 4M0907379Q
    Software version: 0657
    Hardware number: 4M0907379N
    Hardware version: H09
    ODX name: EV_ESP9BOSCHAU536K
    ODX version: 012013
    Long coding: 28AA149C30A40A9E91A25891007E52A2E6269A14280C50891A 004A45676459
    Trouble codes:
    Intermittent
    Date: 2023-02-01 16:34:27
    Mileage: 89529 km
    Priority: 6
    Malfunction frequency counter: 111
    ---: 7B000000420000000000
    Dynamic environmental data: 20961B
    08 Air Conditioning
    System description: Klima Zone 4
    Software number: 4M0820043AB
    Software version: 0112
    Hardware number: 4M0820043AB
    Hardware version: H52
    ODX name: EV_AirCondiFrontBHTCAU736
    ODX version: 001013
    Long coding: 6608090C554801111068018080000000000000000000000000 0000000000
    Trouble codes:
    09 Central Electrics
    System description: BCM1 MLBevo
    Software number: 8W0907063CG
    Software version: 0267
    Hardware number: 8W0907063BG
    Hardware version: H13
    ODX name: EV_BCM1BOSCHAU736
    ODX version: 018006
    Long coding: 07500363E0691CCD050F5719583E1CB911033D019000000000 00000020001A010863012B025709
    Trouble codes:
    13 Adaptive Cruise Control
    System description: LRR4
    Software number: 4M0907561G
    Software version: 0340
    Hardware number: 4M0907561
    ODX name: EV_ACCBOSCHAU736
    ODX version: 003022
    Long coding: B4779FFA58FFEC09959A81A1
    Trouble codes:
    U112200 - Databus implausible message
    Intermittent
    Date: 2023-03-28 16:53:33
    Mileage: 90968 km
    Priority: 6
    Malfunction frequency counter: 7
    Unlearning counter: 165
    Dynamic environmental data: 028D570285821011000010120000102E02
    Intermittent
    Mileage: 90968 km
    Priority: 4
    Intermittent
    Date: 2023-04-29 12:37:54
    Mileage: 92386 km
    Priority: 4
    Unlearning counter: 196
    Dynamic environmental data: 028D540285891011000010120000102E02
    Intermittent
    Date: 2023-04-21 19:22:42
    Mileage: 92033 km
    Priority: 6
    Malfunction frequency counter: 254
    Dynamic environmental data: 028D620285821011160B1012017B102E02
    15 Airbag
    System description: Airbag10.44
    Software number: 4M0959655F
    Software version: 0107
    Hardware number: 4M0959655F
    Hardware version: H02
    Serial number: 003UM001KTH-
    ODX name: EV_AirbaAU10BPAAU736
    ODX version: 006016
    Long coding: AECCFCC000800000A0F00033D24C00000000
    Trouble codes:
    B101629 - Frt.pass. side airbag disabled indicator lamp Implausible signal
    Intermittent
    Date: 2023-02-10 21:33:52
    Mileage: 89789 km
    Priority: 2
    B12F129 - Indicator lamp for front passenger airbag Implausible signal
    Intermittent
    Date: 2023-03-27 15:31:42
    Mileage: 90929 km
    Priority: 2
    16 Steering Column
    System description: Lenks.Modul
    Software number: 4M0907129LS
    Software version: 0009
    Hardware number: 4M0907129LS
    Hardware version: H11
    ODX name: EV_SMLSKLOAU736
    ODX version: 006008
    Trouble codes:
    17 Dashboard
    System description: FBenUSA
    Software number: 4M0920890C
    Software version: 0370
    Hardware number: 4M0920890C
    Hardware version: H18
    ODX name: EV_DashBoardAU736
    ODX version: 001027
    Long coding: 09C700C16C88CF0502A369601800600008000000
    Trouble codes:
    19 Gateway
    System description: Gateway
    Software number: 8W8907468F
    Software version: 0123
    Hardware number: 8W8907468E
    Hardware version: H42
    Serial number: 0187D772817C07
    ODX name: EV_CGateCONTIAU491
    ODX version: 003111
    Long coding: 03010001000006405407000000590032DC1A00071000000001 50000000000000
    Trouble codes:
    28 Rear Climate Control
    System description: Klima Zone 2
    Software number: 4M0919158D
    Software version: 0103
    Hardware number: 4M0919158D
    ODX name: EV_AirCondiFondBHTCAU736
    ODX version: 001013
    Long coding: 00000000000000010080008000000000000000000000000000 0000000000
    Trouble codes:
    29 Light Control Left
    System description: LCM_MLBevo
    Software number: 4M0907397AC
    Software version: 0024
    Hardware number: 4M0907397C
    ODX name: EV_LCMLeftHELLAAU736
    ODX version: 001012
    Trouble codes:
    36 Driver Seat
    System description: MEM-FS
    Software number: 4M4959760
    Software version: 0042
    Hardware number: 4M4959760
    Hardware version: 009
    Serial number: 00000293916245
    ODX name: EV_SCMDriveSideCONTIAU736
    ODX version: 006009
    Long coding: 005C1B000000B0010000010101010000000000000000000000 000000000000
    Trouble codes:
    39 Light Control Right
    ODX name: EV_LCMRightHELLAAU736
    ODX version: 001012
    Trouble codes:
    3C Lane Change Assistant Right
    System description: MRR1Rear
    Software number: 4M0907566D
    Software version: 0410
    Hardware number: 4M0907566
    ODX name: EV_RearRadarS1BoschAU736
    ODX version: 001022
    Long coding: 1EC002
    Trouble codes:
    42 Driver Door
    System description: TSG FS
    Software number: 4M0959793H
    Software version: 0129
    Hardware number: 4M0959793F
    Hardware version: 005
    Serial number: 0000292522535
    ODX name: EV_DCU2DriveSideMAXHCONT
    ODX version: 001005
    Long coding: 005D9B005E001080000920B0
    Trouble codes:
    44 Steering Assistance
    System description: EPS_MLBEVO1BS
    Software number: 4M0909144H
    Hardware number: 4M0909144B
    Hardware version: H22
    Serial number: 0000324054
    ODX name: EV_EPSVWBSAU736
    ODX version: 009023
    Long coding: B0000101000101
    Trouble codes:
    46 Comfort System
    System description: BCM2 MLBevo
    Software number: 8W0907064ED
    Software version: 0387
    Hardware number: 8W0907064DD
    Hardware version: 025
    ODX name: EV_BCM2HellaAU736
    ODX version: 014014
    Long coding: 01341E00492100C0650B80006E01580003024000810000502F 0400000F04803F001E0001000000
    Trouble codes:
    U112100 - Databus missing message
    Intermittent
    Date: 2023-04-29 14:13:26
    Mileage: 92397 km
    Priority: 6
    Unlearning counter: 198
    Dynamic environmental data: 3A3E31693141314E1750400442100280000000000094009D01 0000341D0000000001175500000000
    B147918 - Remote key 1 Voltage too low
    Intermittent
    Date: 2023-03-30 09:06:01
    Mileage: 91027 km
    Priority: 6
    Dynamic environmental data: 3A3E2FA92F8E2FA9175040044210068000000000007E008101 00002C1D000000000117515CFFFFFF
    Intermittent
    Date: 2023-04-24 11:47:06
    Mileage: 92110 km
    Priority: 5
    Malfunction frequency counter: 5
    Unlearning counter: 173
    Dynamic environmental data: 3A3E30C630AB30B9175040040A120498000000000086009101 0000141D0000000001175500000000
    Intermittent
    Date: 2023-01-26 11:29:24
    Mileage: 89438 km
    Priority: 6
    Malfunction frequency counter: 255
    Unlearning counter: 203
    Dynamic environmental data: 3A3E3193314E3177175040045A12029800000000008C008F01 0000041D0000000001175500000000
    47 Sound System
    System description: MIB2_amp_PD
    Software number: 4M0035223C
    Software version: 0440
    Hardware number: 4M0035223
    Hardware version: H03
    Serial number: 00000000064761
    ODX name: EV_AMPMst16C4Gen2BOSE
    ODX version: 001001
    Long coding: 0135060A008AF53AAF0000010000
    Trouble codes:
    50 3rd Row Seats
    System description: MEM-SR3
    Software number: 4M1959760G
    Software version: 0016
    Hardware number: 4M1959760G
    Hardware version: 008
    Serial number: 00000293578799
    ODX name: EV_SCM3rdRowCONTIAU736
    ODX version: 005007
    Long coding: FF041020F1000000000F000000000900000021210900000000 000000440000
    Trouble codes:
    52 Passenger Door
    System description: TSG BFS
    Software number: 4M0959792H
    Hardware number: 4M0959792F
    Serial number: 0000293775397
    ODX name: EV_DCU2PasseSideMAXHCONT
    ODX version: 001005
    Trouble codes:
    5F Multimedia
    System description: MU-P-LNS-US
    Software number: 4M1035880B
    Software version: 1178
    Hardware number: 4M1035880
    Hardware version: 034
    Serial number: A724L0HB042798
    ODX name: EV_MUHig6C3Gen2HBAS
    ODX version: 001115
    Long coding: 013706020000000013220002041A00102F001BE501700904BE
    Trouble codes:
    B11CF53 - Tuner for satellite radio Deactivated
    static
    Date: 2023-01-26 11:31:06
    Mileage: 89438 km
    Priority: 1
    Unlearning counter: 180
    Dynamic environmental data: 0286984FF7FF00000000000000
    B163002 - predictive route data Signal error
    Intermittent
    Mileage: 92033 km
    Priority: 1
    Dynamic environmental data: 028685
    69 Trailer Control
    System description: Anhaenger
    Software number: 4M0907383E
    Software version: 0253
    Hardware number: 4M0907383
    Hardware version: H27
    Serial number: 0463933853
    ODX name: EV_TrailFunctGener2Hella
    ODX version: 001008
    Long coding: 0210000200000000
    Trouble codes:
    6C Rear View Camera
    System description: Areaview 2
    Software number: 4M0907428F
    Software version: 0318
    Hardware number: 4M0907428
    Serial number: C854607JG0600888
    ODX name: EV_CamSysRVAV2CE2MLBEv
    ODX version: 005015
    Long coding: 02350602BB0FA10038404004
    Trouble codes:
    6D Deck Lid Control
    System description: HDSG-Modul
    Software number: 8W8959107B
    Software version: 0163
    Hardware number: 8W8959107
    Serial number: 31697153000000
    ODX name: EV_DeckLidCONTIAU736
    ODX version: 001015
    Long coding: 00B0
    Trouble codes:
    81 Gear Shift
    System description: GSM-LL
    Software number: 4M1713041E
    Software version: 0077
    Hardware number: 4M1713041F
    Serial number: 17120745161884
    ODX name: EV_GSMWaehlZFAU736
    ODX version: 001017
    Trouble codes:
    82 Head Up Display
    System description: HeadUpDisplay
    Software number: 4M0919617B
    Software version: 1640
    Hardware number: 4M0919617B
    Hardware version: H29
    ODX name: EV_HudNSEIKAU736
    ODX version: 001017
    Long coding: 4F01E0
    Trouble codes:
    A5 Driver Assistance
    System description: BVS
    Software number: 4M0907217E
    Software version: 0050
    Hardware number: 4M0907217E
    Hardware version: H16
    ODX name: EV_BVSMLBevKOSTAAU736
    ODX version: 002026
    Long coding: 0407030600000201022023A7A50000B4B0F0C020C020
    Trouble codes:
    Intermittent
    Mileage: 92386 km
    Priority: 6
    Dynamic environmental data: 028D6002858D
    BB Rear Left Door
    System description: TSG HFS
    Software number: 4M0959795H
    Hardware number: 4M0959795F
    Serial number: 0000293679573
    ODX name: EV_DCU2RearDriveMAXHCONT
    ODX version: 001005
    Long coding: 004D9B0000001080400820A0
    Trouble codes:
    BC Rear Right Door
    System description: TSG HBFS
    Serial number: 0000293679574
    ODX name: EV_DCU2RearPasseMAXHCONT
    ODX version: 001005
    Trouble codes:
    CA Sunroof
    System description: SAD_STG_1
    Software number: 4M0907594G
    Hardware number: 4M0907594
    Hardware version: 014
    ODX name: EV_SunRoofCONTIAU736
    ODX version: 006008
    Long coding: 2A8000053602
    Trouble codes:
    CF Lane Change Assistant Left
    Software number: 4M0907590D
    Hardware number: 4M0907590
    ODX name: EV_RearRadarS2BoschAU736
    ODX version: 001022
    Long coding: 1EC002
    Trouble codes:
    D6 LED Module Left
    System description: LED1L
    Software number: 7PP941572AB
    Software version: 0003
    Hardware number: 7PP941572A
    ODX name: EV_LEDModLeftMELCOAU736
    ODX version: 001004
    Trouble codes:
    D7 LED Module Right
    System description: LED1R
    ODX name: EV_LEDModRightMELCOAU736
    ODX version: 001004
    Trouble codes:
    Jan 22 2022
    FL, US
    The air intake flaps are at those two rectangular flex hoses before the engine cover/intake. I had a similar code in mine because they were incorrectly installed and blocking the flaps from moving. You could also take a look at the connector and make sure it's clean/secure. Also looks like your primary key needs a new battery.
    Nov 22 2005
    socal
    Thank you.
    any idea of any of that would cause the drive system malfunction?
    Jan 22 2022
    FL, US
    I don't know for sure. It's fault priority 2 which means immediate shop visit required. I'd say it's plausible.
