2011 Audi A5 Sportback 2.0TFSi Quattro DSG-7speed transmission.
In short: We changed mech circuit board with 3 solenoids (N472, N440, N436). Car still have (all problem starts with same) transmission warning and only even gears available. Became bit better like it can driveable. (not driveable before)
Question is what happens if not aligning the gear forks in neutral position while assembling back? Only thing me and my friend forgot to do is aligning gear forks. We pull out mech unit swapped parts and put it back. forks are same position before and goes back into it.
So was that the problem still there?? is it fixable if do computer adaption and solenoid adaption thing?
Long story:
On 2021-Dec-20th got an gearbox malfunction msg on dash while driving at traffic jam. Odd gears out, only even gears were available. Slowly driven to home, around 8miles. Few days later tries to go near service around 1mile away. Almost arriving destination there was slight steep road like 25-33 angle incline. When droving up to uphill car shakes a lot like gears going in an out multiple times (tried to put in 1st but cant i guess). Then bad thing happened car lost all gears like when put gas on throttle it just roars no were to move. Lost even gears and reverse also. Cannot reached the destination, i managed to turnaround to downhill way stopped there around 20 min, start the car and put in D then even gears available again I go back to home (it was late, service was closed). Upon arriving home gear box makes loud noise like shaking many loose metal plates (I think that not enough pressure made on clutch friction plates) and no gears not driveable since then. Cant get fixed until this week (bcos of covid border closed, quarantine etc).
Bought an 0b5 mechatronics repair kit (2 circuit boards with 3 solenoids) from amazon. Tried to swap it with my friend. We did it around 2hours. Only thing we forgot to do is aligning the forks into neutral position.
After swaping things car got same error but it can driveable again like when all shit starts back in 2021. So i my question is that not aligning fork is causing problem ? or should I need to adaption procedure with computer?
Feel free ask questions and give me advice thank you.
