2014 3.0T 4L
Fairly loud ticking from the passenger side front of the valve cover - stethoscope "listen" seems to indicate its coming from the fuel pump or cam lobe that drives the fuel pump area. No engine codes present when scanned (vcds)
I'm new to the Q7 and 3.0T. Is this a common noise? Does the 3.0T fuel pump have a 'lifter' or 'tappet' follower between the camshaft and fuel pump that needs to be replaced every xx,xxxx kms?
Thanks for any input!
