New to me 2019 SQ5. 52k miles. I got a boost fault one night on the way home from work. Cleared it with my Carista dongle. The car seemed to never really be 100% since. For instance when you floor it the boost gauge will slowly, painfully raise until finally you feel a surge. Once you are finally making boost it seems fine. From a stoplight driving moderate to spirited letting it shift at say 4.5 or 5k the trans is late in 2nd before your really making enough boost to go anywhere. I've been waiting to throw another code. Either another boost fault to confirm it is not just me or some other fault that would shut boost off as a consequence. Like misfire, cam timing etc.
Once it throws the low boost fault it is even more of a turd until the key is cycled. Once I had the throttle wide open for several seconds in a higher gear bogging the engine and I got turbo over speed fault.
The crank case has a lot of pressure. When you remove the oil fill cap while the engine is running it has a lot of pressure behind it. Not sure how much pressure it should be. Seems like it should only be a few mbars though. I smoke tested to see if there are any leaks. None found. The waste gate actuator moves freely and holds vacuum when applied.
I have read there could possibility be some issues with the vacuum solenoids that are on the front of each cylinder head. Like getting gunked up with oil from the vacuum pump??? I work a ton and it's my daily so kinda wanted to see if you guys knew anything common before I start taking stuff apart. No need to reinvent the wheel if it is a common problem. It seems very common on the 2.0 4 banger but not so much google info on the 3.0 V6.
Any info or experience with this issue is very appreciated.
PS please don't ask me if I am driving in S or D. Yes it does it in S and I am setting fault codes.
