Results 1 to 14 of 14
    Apr 16 2023
    Auburn
    DIY Engine, Transmission, Front/Rear Diff, Transfer Case EA839/ZF8HP55
    Excited to bring some NEVER DONE BEFORE maintenance content.
    I’ve seen so many questions on “how to” do the engine, transmission (with pan removal), rear/center diff, and transfer case fluids.
    This covers all those fluids with all specifications from ALLDATA for:
    EA839/ZF8HP55 - B9/B9.5 S4/S5/SQ5 (RS5)
    Don’t pay the dealer big bucks, don’t pay some Joe Shmo. Do it yourself properly. After you see the fluid in my car you’ll want to do your asap!!!
    https://www.youtube.com/watch?v=LAVIVLha-Js&t=76s
    PARTS NEEDED:
    x1 Audi VW Transfer Case Oil
    VAG-G055515A2
    x1 Audi Automatic Transmission Service Kit
    KIT-G060162A2KT
    x2 Audi VW Automatic Transmission Fluid (1 Liter)
    VAG-G060162A2
    x1 Audi Transmission Pan
    VAG-0D5398009
    x2 Audi VW Gear Oil Synthetic 75W90
    VAG-G052145S2
    x1 Audi Porsche Engine Oil Filter Kit
    HEN-E914HD398
    x2 5W40 Leichtlauf High Tech Engine Oil (5 Liter)
    181094
    ALLDATA FILL SPECIFICATIONS:
    3.0L Engine (CWGD) - 7.25L (7.7 qt.)
    8-Speed Tiptronic Transmission
    Refill 3.6L - 4.0L (3.8 qt. - 4.2 qt.)
    Refill (Pan Dropped) 5.5 qt. - 6.0 qt.
    Front Final Drive - Refill 0.9L (0.9 qt) Approximately
    Transfer Case - Refill 0.8L (0.8 qt.)
    Rear Final Drive (0D3) 0.95L (1.0 qt.)
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Great video, I appreciate the walkthroughs.
    Quote Originally Posted by Need4Built View Post
    “Look how easy it is!”
    Has access to a lift and a fully equipped garage…
    iain
    Apr 16 2023
    Auburn
    It's a local self service garage. anyone can rent a space/lift. I would recommend you try to find a similar location near you.
    You can absolutely do this yourself on jack stands however, I didn't for the sake of better content. Thank you!
    Established Member Two Rings BrosephSQ5's Avatar
    Apr 27 2022
    Texas
    Great walkthrough. Don’t mind @Hostile. He’s a continuous douche in these forums.
    ____________________________
    2018 SQ5 Premium Sport Plus
    Moonlight Blue Metallic
    Apr 08 2011
    NoVA
    There aren’t any of those around here. It would be nice if there were.
    iain
    Jul 13 2018
    Winnipeg, MB, Canada
    I saw the video on youtube, it will prove very useful I'm sure.
    Mar 29 2021
    State College, PA
    Quote Originally Posted by BrosephSQ5 View Post
    Glad I'm not the only one who noticed!
    Veteran Member Three Rings JonnyBravo!'s Avatar
    Oct 26 2014
    2018 SQ5 | 2017 A3 e-tron
    California
    This is just what I needed. No shop is willing to do the transmission fluid service for me, so DIY it is. Thank you for this.
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    The king is back at it making the shopping list easy for us. Thank you.
    When I get around to this job I'll add all of the torque specs to the thread, I'm approaching 50k miles myself.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Mar 25 2015
    Placer County
    Great video, I appreciate the walkthroughs. Fuck you.
    ^actual quote
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Apr 08 2011
    NoVA
    Quote Originally Posted by Gunnarrrrr View Post
    ^actual quote
    lol
    iain
    Apr 27 2022
    Texas
    ^actual quote
    And yet another…
    Mar 25 2015
    Placer County
    @OP, I found some info on rear diff ATF draining and filling in the manual, not sure if you find it necessary to flush this as well as the regular diff fluid?
    Anyone feel free to correct me if I'm wrong, but 0D3 is the standard diff, 0BX is the torque vectoring sport diff.
    Anyway I got bored and figured I'd just write this up now and save it for later, in case anyone wants to tackle it before I did.
    All direct info from the service manual, just chopped up and spliced to fit on one page. with torque specs.
    Rear Final Drive 0D3 & 0BX
    • Remove gear oil inspection plug -arrow-.
    • The gear oil drains out of the drain hole faster if the inspection
    plug is removed.
    • Remove gear oil drain plug -arrow- and drain off gear oil.
    • Screw in and tighten new gear oil drain plug -arrow-
    • The oil level is correct when the rear final drive is filled to the bottom lip of the filler hole.
    • Top up gear oil again if necessary.
    • Tighten & torque inspection plug
    All tightening torques for fill & drain plugs for gear oil and ATF on both 0D3 & 0BX are 15Nm / 130 in-lbs / 11 ft-lbs
    0BX plug locations:
    (1) - inspection plug
    (2) - drain plug
    Your rear diff does not only have gear oil. THERE IS ALSO AN ATF RESERVOIR THAT CAN BE FLUSHED
    Same exact procedure as the gear oil flush in the rear diff, however there is a software diagnostic function titled "Adding ATF" to vent air from the system and detect any air in the system for this.
    0D3 inspection plug:
    0D3 drain plug:
    0BX inspection plug (1) & drain plug (2):
    https://i.ibb.co/Yppzt2m/image.png
    Front Diff:
    Requirements
    • Engine not running.
    • Vehicle must be absolutely horizontal (on a four-pillar lifting platform or over an inspection pit).
    • Gearbox is in position “P”.
    • Parking brake button must be pulled up to apply the electro‐mechanical parking brake.
    Draining
    • Unscrew drain plug -arrow B- on front final drive and drain off gear oil.
    • Tighten new drain plug -arrow B- on front final drive.
    Filling up and adjusting oil level
    • Gear oil about 20 ℃ (room temperature)
    • Unscrew plug for inspection and filler hole -arrow A- on front final drive.
    • Connect hand pump for filling gearbox - VAS 6617- and fill up front final drive with approx. 1.0 ltr. of gear oil. Wait for 5 minutes.
    • It is necessary to wait for at least 5 minutes to allow the internal oil level to balance out between the differential and the baffle chamber. – Then detach -VAS 6617/6- from gearbox and allow excess gear oil to drain off.
    • Tighten new plug -arrow A- on front final drive. The level does not need to be re-checked after this step.
    Tightening torques
    • (7) Drain Plug - 10Nm / 88 in-lbs / 7.5 ft-lbs
    • (6) Filler Plug - 27 Nm / 20 ft-lbs
    Transmission
    • Lift gearbox slightly using engine and gearbox jack.
    • Unscrew bolts -arrows- and remove tunnel cross member
    • refer to transfer case draining & filling below, then proceed to the rest of the ATF change
    Draining
    • Remove ATF drain plug -arrow A- and allow ATF to drain off.
    • Tighten drain plug -arrow A- as far as stop.
    Pan
    • Move electrical wiring clear.
    • Remove bolts for ATF oil pan in the sequence -12 ... 1-
    • Remove ATF oil pan.
    • Installation is carried out in reverse order
    • Screw in bolts -1, 2- by hand until bolt heads make contact.
    • Tighten bolts in specified sequence.
    Tightening torques
    Filling
    • Unscrew plug for ATF inspection and filler hole -arrow B-
    • Fill up with ATF via adapter until ATF comes out of inspection and filler hole.
    • Start engine with selector lever in position “P”.
    • Continue filling with ATF via adapter until ATF comes out of inspection and filler hole again.
    • Hand-tighten old plug for ATF inspection and filler hole
    Check ATF level and top up as required
    • Air conditioner and heating switched off.
    • Vehicle diagnostic tester is connected.
    • The ATF temperature must not be higher than 30 ℃ at the beginning of the test. If the temperature is higher, allow the gearbox to cool down before proceeding.
    • ATF level will change depending on ATF temperature. If ATF level is checked when ATF temperature is too low, this will lead to overfilling. If ATF level is checked when ATF temperature is too high, this will lead to underfilling. Both overfilling and underfilling will impair the function of the gearbox.
    • Read off ATF temperature. Specification: maximum 30 ℃.
    • The ATF level is correct if a small amount of fluid comes out at the ATF inspection and filler hole when the ATF is at a temperature up to 40 ℃
    • Renew plug for ATF inspection and filler hole.
    Note
    • Switch off ESP.
    • To fill up torque converter, keep engine running at 2000 rpm for 30 seconds with selector lever in position “P”.
    • With engine idling and brake pedal pressed, move selector lever to “P” and “D/S” (leave selector for 10 seconds in each position).
    • Shift gearbox into position “P”.
    • Allow engine to continue running at idling speed.
    • Unscrew plug for ATF inspection and filler hole; drain off any excess ATF if necessary
    • If ATF comes out of the ATF inspection and filler hole before the ATF has reached 40 °C, the ATF level is OK.
    • If no ATF comes out of the ATF inspection and filler hole before the ATF has reached 40 °C, top up ATF
    • The ATF inspection and filler hole must be closed again before the ATF reaches a temperature of 40 ℃.
    • Tighten new plug for ATF inspection and filler hole. The ATF level check is now completed.
    Topping up ATF
    • If no fluid comes out of the ATF inspection and filler hole when the temperature reaches 40 °C:
    • Plug for ATF inspection and filler hole must be screwed in again before temperature reaches 45 ℃. If necessary, switch off engine, allow gearbox to cool down and repeat the test.
    • Insert adapter for filling ATF oil - VAS 6262/5- into ATF inspection and filler hole
    • The ATF level check is now completed.
    Tightening Torques
    • (1) ATF drain plug - Tighten as far as stop
    • (5) ATF fill plug - Renew - 30Nm / 22 ft-lbs
    Transfer Case:
    • Remove drain plug -arrow B- and allow gear oil to drain off.
    • Tighten new drain plug -arrow B-.
    • Unscrew plug for inspection and filler hole -arrow A- on centre differential housing.
    • Connect hand pump for filling gearbox - VAS 6617- and fill up transfer box with approx. 1.0 ltr. of gear oil.
    • It is necessary to wait for at least 5 minutes to allow the internal oil level to balance out between the centre differential and the baffle chamber. – Then detach -VAS 6617/6- from gearbox and allow excess gear oil to drain off.
    • Specification: Oil level is correct when oil in transfer box is up to lower edge of filler hole. Top up with gear oil once again if necessary.
    • Tighten new plug -arrow A- on housing for centre differential. The level does not need to be re-checked after this step.
    Tightening torques
    • (3) Drain plug for gear oil in transfer box - renew after removing - 12Nm / 106 in-lbs / 9 ft-lbs
    • (4) Fill plug for transfer box - renew after removing - 27 Nm / 20 ft-lbs
    Tunnel Crossmember Reinstallation
    • (9) Nut - 20 Nm / 177 in-lbs / 14 ft-lbs
    • (1) Bolt - 55 Nm / 40 ft-lbs
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Senior Member Two Rings ccssid's Avatar
    Jul 03 2011
    michigan
    plug is removed.
    0BX plug locations:
    (2) - drain plug
    an alternate method:
    https://www.audizine.com/forum/showt...1#post14922960
    2011 S4 prestige. Imola 6mt.
