Results 1 to 16 of 16
    Aug 07 2022
    Eagle, Co
    removing screen from master cylinder reservoir
    Hi guys-
    Whats the trick for removing the screen inside the cap on the brake/clutch reservoir? I'm tired of breaking plastic parts by forcing them! I figure there's a better way.
    Thanks
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    Interesting question - I honestly didn't think there was a way to pull that thing out of there. Let me know if you figure it out as I would love to de-gunk mine one day.
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Very easy
    You need to disengage a small tab on one side and pull up
    I used a jewelers screwdriver (small) and pulled up using a needle nose plyers
    Note the white spot on the screen insert- that's where the screw driver engaged the tab
    Note the orientation relative to the slots on the top- gives you the location of the offending tab
    Sent from my SM-A146U using Tapatalk
    Aug 07 2022
    Eagle, Co
    Thanks! I'll give it a try tonight. Is the tab between the basket and the res? or inside the basket?
    Apr 08 2013
    Connecticut
    It's on the basket....outside surface
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    Wait...why do you want to do this?
    Aug 07 2022
    Eagle, Co
    to siphon out the brake fluid thats in there before I flush the system.
    Sep 14 2013
    You exchange res fluid by removing the small yellow cap
    Apr 08 2013
    Connecticut
    Quote Originally Posted by PwrWgn View Post
    Granted that's why that small yellow cap is there (to expose the evacuation nubs for both sides of the reservoir) but old habits are real hard to break---ie- ye old turkey baster...
    Aug 07 2022
    Eagle, Co
    Oh jeez I feel stupid. I never considered what that yellow cap was for...one more reason why this forum is so great! Thanks guys
    Veteran Member Three Rings mjmatos's Avatar
    Apr 29 2014
    Long Island, NY
    Honestly good to know I just power bleed all fluid through each caliper, this is way better
    Current
    2001 B5 S4 Sil | ASP Stg 3 | RS6 K04 | Rosten Rods | AWE SMIC| RS4 Engine and Trans Mounts | AMD Stg 3+ | CM SMFW | StopTECH BBK | ASP DP + Exhaust | Tein SS Coilovers
    2001 B5 S4 BB | Blake tuned | E85 | SRM K24 Hybrid | SRM v3 IC | Full SSAC DP + Exhaust | 034 Motor Mounts | CM FX400 | 17z BBK | BC Coils | Wallbro 450
    R.I.P
    2005 B6 A4 1.8TQM | REVO Stg 2| RNS-E | B7 S4 Brakes | ST Coilovers
    2001.5 B5 A4 1.8TQM | Stg 3 | GTRS Elim | Meth
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    I didn’t know the small cap was for removing fluid.
    Personally I always took the screen out. Is there a gasket that goes with the yellow cap? That might need replacing if removed?
    + 1 for Audi making this cap.
    Aug 07 2022
    Eagle, Co
    I've been thinking of getting a power bleeder. I can see how it makes one person bleeding simple, but is it any more effective than having a kid push the brake pedal while I crack bleeders? Is there any concern about screwing up calibration of anti-lock brakes assuming I don't get air in there?
    Veteran Member Three Rings q20v's Avatar
    Nov 12 2014
    2001 Audi A4, 2001 Audi S4, 1988 BMW 530i
    Ottawa, ON
    There’s an o-ring for the small yellow cap. Usually reusable but I’ve had one distort and extrude out during reinstallation before. Just be careful with it and it should be okay.
    Aug 07 2022
    Eagle, Co
    So the nipples under the yellow cap allow sucking out 98% of the fluid in the master cylinder reservoir. Pretty slick. Used my mity vac to pull out the fluid. Almost as good as the turkey baster!
    Aug 30 2015
    Derry NH
    Anyone have a picture of what it looks like under the yellow cap?
    I have a pneumatic fluid extractor. But if there’s nipples, that might not work?
    Hmh800 -
    I have been using a power bleeder for years. They work great. As long as your brake master is working properly.
