Results 1 to 6 of 6
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    Replacement Wheel lock key
    Looks like I've lost my factory wheel lock key. Assuming these are only available from the dealer. Does anyone know if they need to see the locking lug or can they look it up by VIN? And price? Know of any dealers that have better pricing than others?
    Thanks in advance.
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    Where I reside, the wheel locks are dealer installed during PDI. The VIN wouldn't help if this is the practice everywhere.
    Sent from my Pixel 7 Pro using Tapatalk
    Jul 16 2018
    Atlanta
    The wheel locks are identified by a letter code. You just order the part number with the color code for the key code you need. They're not high security, just there to prevent in-the-moment mayhem.
    There's resources on the net for looking up the patterns, matching code, etc.
    Feb 02 2018
    CO
    Quote Originally Posted by Smac770 View Post
    Thanks. Been seeing pictures online, but haven't found the letter code that matches my key code yet.
    Feb 02 2018
    CO
    Found my wheel lock key. No need for me to keep searching for a replacement, although I was able to determine the letter code. Seems these are fairly readily available online. And Audi should be able to order a replacement as well. Some of the one's available online don't get good reviews (too soft and won't last).
    Jul 16 2018
    Atlanta
    Yeah, maybe something like this. https://www.ebay.com/itm/385400788155
    When we look at the parts catalog for the B8.0 A5/S5 at the wheel bolts page:
    https://www.ilcats.ru/audi/?function...20&language=en
    You see the locking wheel bolts, you order them by color code for a pattern A through X.
    edit - or finding the original is the easy way :-D
