Results 1 to 10 of 10
    Junior Member One Ring
    Feb 14 2021
    Goldsboro, NC
    Ghost cylinder 2 misfire - 2012 Audi A4 2.0t
    Bought a used A4 PP 2.0T 6 Speed last year. About 2 months ago it started misfiring. I hooked it up to VCDS and it didn’t show any codes besides “Multiple cylinder misfire”. I checked cam phase and was at -5.7 degrees. I was also getting misfires across all cylinders, but number 2 was MUCH higher. After completing the timing chain job, new Bosch injectors, and carbon cleaning I am still at a misfire on cylinder 2 only. Compression is good 175-200 across all 4, leak down was less than 4%, (good). Any other ideas? Misfire goes away with RPM above 1,000.
    I am leaning toward removing the head. But I really do not want to.
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Quote Originally Posted by Audiguy92 View Post
    When mine did exactly the same thing, it was a blown up rocker and wrecked cam lobe
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    I presume you've swapped plugs and moved coil packs between cylinders to see if it follows?
    Sent from my SM-N976V using Audizine Forum mobile app
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Feb 14 2021
    Goldsboro, NC
    Yes, all new NGK R plugs gapped properly, all new VW\audi coils. And even swapped since install to verify.
    Feb 14 2021
    Goldsboro, NC
    So, the engine was money shifted before I purchased the car. My Local shop said that they found the retaining clips for one of the rocker arms that detonated before. No damage on the cam though. Any more ideas?
    Feb 15 2016
    Cambridge,Ontario
    if it was money shifted id be taking another look at that top end. not saying they are not a good shop, but things can happen at high revs.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 12 2013
    If it was a true money shift, I'd expect more damage. Could be a slight misshift and you might be lucky.
    I'm with iceman, I'd replace all rockers and lifters for sure. Inspect both cams completely. All lobes and guides. The exhaust cam, make sure the lobe pairs can slide without interference. For the intake cam, I would be concerned on the stator inside the VVT adjuster.
    Build Thread
    Feb 14 2021
    Goldsboro, NC
    I finally got it. One of the roller rockers was flat spotted. I have now spent $4,000+ chasing a $9 part
    Feb 15 2016
    Cambridge,Ontario
    yeah thought it might be a top end issue. glad you got it sorted . i don't trust shops .. even ,"well regarded" ones
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
    Jun 12 2013
    VAG updated the rocker design too. I bought the newest revision for my new build. Could be the case here..?
    I've be concerned with the cam's lobe condition above that rocker. In addition, check the other rockers. If you see similar wear, I'd be concerned with an oil delivery issue.
    Build Thread
