I've noticed my Auto HVAC blowing colder air than normal. I usually just leave it set at 68-70f but its been a little off lately. The ambient temps in Ohio have been in the 40's and 50's for perspective. I can't speak to AC / cooling performance yet.
A VCDS scan showed the following:
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Component: KLIMA 3 ZONEN H04 0123
Revision: C1000000 Serial number: 01020920140584
Coding: 6480208000
Shop #: WSC 02391 785 00200
VCID: 77ABE8C5CFC4AEA23E9-8022
1 Fault Found:
01187 - Rear Temperature Flap Positioning Motor (V137)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 222
Mileage: 128243 km
Time Indication: 0
Date: 2023.03.26
Time: 16:42:44
Freeze Frame:
Voltage: 14.40 V
Temperature: 20.0°C
Temperature: 16.0°C
Count: 10000
Count: 9772
Bin. Bits: 01000000
Bin. Bits: 00000111
Time: 255.00 s
This error comes back after clearing and running through the function tests in VCDS again. I believe the temperature flaps are on the driver side but can anyone confirm this? Seems like it should be an easy fix as long as this particular motor is accessible. Does anyone have any experience or input on this fix?
