Results 1 to 10 of 10
    Jan 09 2023
    New York
    Ctrl Module faulty
    Ctrl. module faulty
    Fault code:
    B200004
    Status:
    static
    Priority
    4
    Malfunction frequency counter
    1
    Unlearning counter
    255
    Mileage
    44032.23 miles
    Dynamic environmental data
    ЗА3Е33533353334517501B02A09004E00000119F00770 097
    010000001C0100000001175600000002
    Date
    2023-04-02 12:04:14
    I just saw this faulty. What does it mean?
    What should I do?
    Senior Member Three Rings c99's Avatar
    Feb 28 2009
    RS5 2.9TFSI - dead engine
    EU, CZ
    Which control modul?
    Car has got around 20 control moduls.
    Jan 09 2023
    New York
    I don’t know…what I upload is all I could see
    Jul 16 2018
    Atlanta
    What are you using to read this DTC? What control module was it connected to when it presented this information?
    Mar 26 2010
    US
    +1
    Quote Originally Posted by Smac770 View Post
    What are you using to read this DTC? .....
    What are using to scan the codes?
    You need to look at the whole system and details.
    I have Ross-Tech VCDS & OBDeleven.
    One phantom code from a module can cause a DTC. Here is an example of a DTC Fault code:
    B200004 phantom code from a 2020 Q3: https://static.nhtsa.gov/odi/tsbs/2020/MC-10171346-0001.pdf
    BMW M3 Competition X-drive
    Jan 09 2023
    New York
    Quote Originally Posted by wwhan View Post
    +1
    I was using OBD11
    Your Q3 problem has solved?
    Jul 16 2018
    Atlanta
    OBDeleven, that's common enough platform that how to use it should be readily available. To look at the error, I assume you had to go into one of the control modules, which one was it?
    Or just find the history log after a full vehicle scan and post that, at least then the state of all the car modules will be seen.
    The TSB referenced refers to the MIB2+ unit, the J794, at 5F - information electronics. What model year is your A5? Is it MIB2 (rotary dial) or MIB3 (touchscreen)? Is its software up to date?
    Have you been using OBDeleven to make modifications to the vehicle?
    Jan 09 2023
    New York
    OBDeleven vehicle history log
    Date: 2023-04-21 20:29:31
    VIN: WAUBNCF5XJA094900
    Car:
    Year: 2018
    Body type: Sportback
    Engine: CYMC kW ( hp) l
    Mileage: 44273 mi
    46 Comfort System
    System description: BCM2 MLBevo
    Software number: 8W0907064EC
    Software version: 0387
    Hardware number: 8W0907064DC
    Hardware version: 025
    Faults:
    B200004 - Ctrl. module faulty
    static
    Priority - 4
    Malfunction frequency counter - 1
    Unlearning counter - 255
    km-Mileage - 70863 km
    Dynamic environmental data - 3A3E33533353334517501B02A09004E00000119F0077009701 0000001C0100000001175600000002
    date - 2023-04-02 12:04:14
    B16D531 - left tail lamp 2
    No signal
    Intermittent
    Priority - 5
    Malfunction frequency counter - 16
    Unlearning counter - 126
    km-Mileage - 71010 km
    Dynamic environmental data - 3A3E2F582F4A2F4A17501B00AA1026E000000000008E009601 000000220000000001175500000000
    date - 2023-04-16 10:45:20
    B16D431 - left tail lamp 1
    No signal
    Intermittent
    Priority - 5
    B16D631 - Right rear tail lamp 1
    No signal
    Intermittent
    Priority - 5
    B16D731 - Right rear tail lamp 2
    No signal
    Intermittent
    Priority - 5
    U112100 - Databus missing message
    Intermittent
    Priority - 6
    Malfunction frequency counter - 29
    km-Mileage - 71031 km
    Dynamic environmental data - 3A3E309E309E309E175040040A120498000000000092009301 000004220000000001175500000000
    date - 2023-04-16 11:19:44
    Jan 09 2023
    New York
    By the way the tail lamps are fine as usual.
    I changed all the codes that I changed before.
    SBBR-variant (I don’t know what it is, but it’s in the history. I changed the value to 0 from 2)
    Intelligent_tail lamp 1,2,3,4 (changed to not installed from installed)
    That’s it. I didn’t change anything other than those.
    and there is one thing coming out in the history
    ADDED - (C8) Auxiliary Display Control Unit 2 in 5F - Multimedia
    There is Engine Start System: malfunction error keeps coming out.
    Jul 16 2018
    Atlanta
    "ADDED - (C8) Auxiliary Display Control Unit 2 in 5F - Multimedia" So why was that done? Do you even have one of those? Looks like more OBDeleven "we're going to make a bunch of random changes to the vehicle configuration and screw something up, because that's what we do". Databus missing message typically means something is misconfigured. Either an unsupported option was enabled, or some device that isn't there is configured as being there, etc.
    From what I can find, Aux Display Control Unit 1 and 2 are a VW thing. We see this as well in that the adaptation list for an A3 MIB references the two control module names, while the adaptation list for an A4 MIB does not.
    You probably need to go into the installed modules list (should be under 19-can gateway) and uncheck C8. We see the MIB J794 (5F) has measuring values for the installed modules list, which means it's probably seeing the setting and wondering where this control module is, it's not responding.
    "SBBR-variant", I don't know what it is or does, but I changed it for the fun of it. ....? Apparently selects the variation of tail animation, with a value of 0, 1, or 2. Ie, frivolous stuff.
