Originally Posted by
DisGrnS5
Apologies if this has already been discussed but I searched the forums and couldn't find a good answer. I would like to increase the front brake rotor size on my B9.5 S5 primarily for aesthetics. Is the stock brake caliper compatible with a larger rotor or would the caliper need to be upgraded too? Are RS5/RS4 stock rotors/calipers bolt-on upgrades for the S5? I seen the Brembo BBK but I would like to keep the set up as OEM-looking as possible.
Honestly....this is the worst possible place to add weight anywhere on the entire car. Brakes really should be as small as possible to get the job done. Aesthetics should focus on higher quality calipers and colors. Now if you want to increase rotor size and go to ceramics, that is a different matter, as you will drop massive amounts of weight. But that is a serious outlay of cash to do aftermarket. Alternatively, you can even drop your wheel size by an inch (depending on what you have to begin with). This will not only drop weight, but also allow your wheel barrel to appear more "filled" by your stock calipers which I think is the look you are trying to achieve. Keeping unsprung mass as low as possible can dramatically affect your ride quality and steering responsiveness and make for a much more enjoyable driving experience.
The
reason there is an aesthetic appeal to larger brakes is that our brains associate this with higher performance, but that just isn't the case here. I look at the Porsches I have owned, and while they all have nice high grade calipers, the actual rotor size is as small as possible for the particular vehicle.
