2004 A4 B6 Quattro Tiptronic with 90k miles. I had the clunk when putting it into reverse with limp mode and the P0706 code. I replaced the transmission range sensor and everything has been great for 2-3 weeks. But this morning, it started doing the same thing again. Just ran a scan and the P0706 code has returned. Is it likely the transmission range sensor I bought is also bad? Or is it a wiring issues somewhere? Any ideas/hints where to start tracing some of that down? It will be next weekend before I can start tearing it apart, but if I need to buy parts, I'd like to get them ahead of time.
Newest Scan:
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 P
Component: AG5 01V 1.8l5VT USA 1213
Coding: 0001002
1 Fault Found:
17090 - Transmission Range Sensor (F125)
P0706 - 003 - Implausible Signal - MIL ON
The switch I purchased:
https://www.amazon.com/dp/B07V3272BP
