greetings all! I'm trying to find some guidance around the known starter/alternator issue and how your experiences with the dealer have gone. I'm aware of the warranty extension, which is great in this case, but my scenario is becoming a bit more challenging after having the alternator fail on me mid-drive on a highway. (2019 A6 Prestige)
As you can imagine, I received the electronics malfunction error in yellow which has reared its head in the past for a simple loose battery cable so on this particular morning I thought nothing of it. Turns out, the alternator had failed and I was unaware until I received a PULL OVER NOW red warning and as I slowed down to do so, the cars instruments/engine/transmission would all start flickering on and off as the batteries were coming to zero charge left. Eventually the car shut off and I drifted to a should space where I could be towed.
Now fast forward to the dealership working on the car. I'm being told that the alternator/starter will be replaced, no questions asked, but the larger battery (assuming 55TFSI battery) in the car has zero charge and it might be damaged due to it being completely depleted. Guidance is that they will try to charge it back up with a new alternator, but if that does not work, that is an out of pocket expense for me (a few thousand bucks I'm being told).
Now I know the legal language in the warranty extension says its not responsible for failure of other parts due to the alternator, but this seems DIRECTLY related to its failure in my opinion and thus I should not be on the hook for replacing it. I'm waiting for results to what path this goes down still, but curious if anyone else has had a similar experience and a better outcome?
