Results 1 to 12 of 12
    Veteran Member Three Rings Ray1031's Avatar
    Nov 01 2015
    San Antonio, TX
    Coolant question emergency
    So the upper radiator hose busted earlier today, was able to get a replacement at AutoZone. When it comes to coolant I ran out of Audi/VW coolant and I used a pink Preston (European car formula) to get me going . Any issues with it ? Has anyone used it? Should I be worried about it ?
    Veteran Member Four Rings Ozone510's Avatar
    Feb 15 2016
    Audi A4 B8 Avant 2.0T, Audi A4 B7 2.0T SOLD, Audi TT 8J Cabriolet VR6 DSG
    Hayward, California, USA
    Quote Originally Posted by Ray1031 View Post
    Should be fine as long as it's the pink stuff and the correct G12 rating or whatever rating these cars use.
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    Sep 10 2021
    Pennsylvania
    It's what I use. G12, pink, raspberry flavor. Should be good to go!
    Feb 15 2016
    Quote Originally Posted by Mike Tries View Post
    I didn't know they were flavored, wtf I'm about to go fill up my cup BRB
    Jan 24 2010
    Paramus,NJ USA
    I would not be using that. That shit never works or is compatible as they state. In a pinch if you need to get home sure. But flush the system and put the correct coolant in it. Never ever trust prestone.
    Ziddy Autowerks
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    How about Zerex G40? Same OE color, same Si-OAT chemistry. It's what I have in my...........3.0.
    Sep 10 2021
    Pennsylvania
    Quote Originally Posted by EuroxS4 View Post
    I guess a cooling system flush after a rebuild probably isn't a bad idea anyway. I'll swing by Audi and pick some up.
    Veteran Member Three Rings codemode's Avatar
    Sep 01 2019
    EU
    I just use a cheap generic pink G12+. No problems with it. VW coolant is not some magic liquid, you’ll be fine, just don’t mix it with other stuff such as G11.
    A4 B6 1.8T Manual FWD 2002
    Painted lowers, USP front
    18'' RS4 ET 35 Replicas
    Oct 12 2018
    B5 S4 Avant 2.7t 6MT
    https://blog.fcpeuro.com/how-to-pick...t-for-your-car
    This FCP article helps for a better understanding of antifreeze and options.
    Sent from my Pixel 7 using Audizine Forum mobile app
    AKA: gjweyman
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by codemode View Post
    If that's the case put some toyota pink coolant in your vehicle and then try to tell me it doesn't eat the aluminum based on its chemical properties. Coolant is formulated for a reason.
    Ziddy Autowerks
    Sep 01 2019
    EU
    Well the generic one I’m using is compliant so no worries there. I always check if it is up to spec.
    Nov 03 2010
    Fallbrook, CA
    Huh? Toyota coolant eats Aluminum? Toyotas engines have plenty of Aluminum exposed to the coolant, but I hadn't heard that Toyota engines are decomposing from within due to their coolant.
