Originally Posted by
SwankPeRFection
You sure you didn’t knock the ESP sensor wire or sensor loose or damaged it in any way? If you did lines, the back ones are really tight when removing the caliper and they need to be uncoupled so as not to damage them by tugging. I’d check that out again on that corner or all corners if you touched all the lines.
Also, if you swapped lines and you did the brake bleed procedure via VCDS, you need to drive the car around via the drive routine they describe for ESP readiness. If you didn’t do that, that’s why the ESP fault is triggering. It’ll actually show up as a code in the ESP/ABS module until that drive routine is completed. Basically drive around the parking lot and go in circles slowly left and right and then straight and it’ll go away and clear. It’s like the ESP version of setting readiness codes for O2 sensors.
So far, I only did the rear passenger side,
I have not touched any other sides (yet). I basically removed the rear caliper, changed the brake line, put it back, connected everything, and bled the caliper.
For the rear passenger side, I checked the ABS sensor and the parking brake sensors, they both work. How do I know? If I disconnect them, I get ABS/traction control related errors (actual errors logged). I am also able to see the wheel speed exactly the same on all 4 wheels. This tells me everything electrical should be fine in that corner. Parking brake works as well, no errors for that.
I did not do the brake bleed procedure via VCDS. Where can I find it? I dont see any codes under the ESP/ABS module right now...
