Originally Posted by
FrankTsui
Just wondering what is the safe turbo pressure limit of the stock engine and fuel system? Tuners told me the engine could do stage 3 without replacing any engine hardware except turbo and could do more than 3 bar (absolute) pressure without sacrificing anything.
I don't think there are easy answers here. I doubt we're going to get a specific number that we all agree is perfectly safe and a number that's dangerous. Obviously more boost creates complications from heat, pressure, etc... Furthermore, it's not just how much boost pressure, but also how efficient the turbo is and how much total air you're putting in there in terms of mass (M = V * d). You might only be adding say 0.3 bar but the bigger hybrid turbo is putting more air mass into the engine. In simplest terms 3 bar through a drinking straw isn't the same as 3 bar through a garden hose. More air mass results in more power from combustion with adequate fueling. So ultimately it's not just the pressure you're worried about, but weather the engine will handle the extra power and if the fuel system will manage the demand. How safe that is will be complicated by mechanical tolerances, existing engine wear, fuel system wear, environmental conditions, maintenance, etc...
Stage 3 at 3 bar including atmospheric pressure seems about right, I see right around 28 psi above atmospheric (I'm at sea level) on my TTE 710 with 034's Stage 3 E85 tune. The general consensus from tuners is this is safe on the stock block, but I doubt you'll find anyone willing to actually warranty that. So far there are a good amount of Stage 3 cars and we're not seeing engine failures left and right. Ultimately the more you modify the car the more risk you take, this is one reason some people will buy a $100k+ car vs. putting $20k in mods into a $40k car even though the modified car might turn out just as fast or faster.
