I had created a thread last week with no luck regarding a howling/grinding noise, quiet but noticeable and constant from 10mph+. Noise does not change with turning like a bad wheel bearing, brakes have plenty of life left. I'd originally brought it to my preferred local Audi indy shop as I thought my front driver axle was failing and asked them to replace that and diag the howling noise if they had time; heard back, was told axles were fine but howling noise was from a bad rear diff that needed replacement. I found a used lower mileage diff at a local salvage yard, supposed to be delivered to the shop today. However, I stumbled on this thread (https://www.audizine.com/forum/showt...l-Box-failures) and one of the posters mentioned that a bad front Bevel Box can cause both a howling noise while driving AND a "binding"/"clicking" type noise/sensation while turning. Months ago I had a random issue that only occurred for about 20min, car refused to go over like 20mph and when I tried to push it, just felt like when you're running out of fuel, but the traction control light kept flashing; if I backed off throttle it'd stop, but trying to give it throttle did nothing. This disappeared a half hour or so later and hasn't returned, freaked me out good though.
So, basically, wondering if all my above symptoms could be explained by a failing front Bevel Box (before I go and have them do the rear diff!). I can't seem to find the location on a diagram, a part #, or a photo of it though. All I can find on Audi's parts catalog is the rear "AWD coupling unit" which on ECS comes up as a Haldex Control Unit but says it doesn't fit my car
Sent from my SM-N970U1 using Audizine Forum mobile app
2015 Audi S3
