Results 1 to 31 of 31
    Oct 18 2017
    NW Philly
    Walnut blast for CREC?
    Having PCV and cold start idle codes.
    Indy suggested a valve cleaning while the supercharger is off if I bring it in. No one has looked at it yet.
    Does the CREC need that even though it has dual injectors?
    2016 A6 3.0 with 84xxx miles
    Oct 21 2021
    2019 A6 Prestige
    Not an expert, but my understanding of the CREC is no, that's not required any longer.
    2018 A6 3.0 P+ Sport - Stg 1 APR - IE Intake - RS6 Seats - S6 Sport Exhaust
    2019 A6 3.0 Prestige
    Sep 16 2020
    West Michigan
    I have heard of people with CREC still needing to have the walnut blast performed on occasion.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Oct 18 2017
    NW Philly
    Thanks, that's what I thought. Plus she gets the Italian tuneup once a week.
    I'm guessing that I should have some other things done "while it's open"
    -thermostat
    -water pump
    -coolant crossover pipe
    -intake gaskets and other breather pipe/check valve pieces
    -aux drive belt (not SC belt)
    Anything else?
    Hopefully no additional things like valve cover gaskets...
    Jan 26 2019
    Tulsa
    Tune your car to run on e85 and your valves will be clean......
    Oct 18 2017
    NW Philly
    I would like an IE stage 1 and TCU.
    I hear the TCU really makes a difference in daily driving.
    But nooooo. Car needs maintenance, and when it rains it pours.
    Veteran Member Four Rings quattroism25's Avatar
    Jun 04 2007
    Exiled in Utah
    This was mine at 120k when I did PCV and walnut blasting. You're already in there, might as well do it.
    Daytona Grey S7
    MORO BLUE JHM modded V8 Sold
    Established Member Two Rings cadguy77's Avatar
    Jun 07 2019
    London, UK
    Quote Originally Posted by quattroism25 View Post
    On what car/engine?
    Sent from my SM-S908B using Audizine Forum mobile app
    '15 CREC SB | Black/White Napa | Sports Diff | Dynamic Steering
    TVS ECU/TCU | Intake Mods | 82mm TB | Ported SC | 034 SC Clutch Delete | KI 206mm Crank Pulley (3.26PR) | Merc Racing HE | Bilstein B16 PSS10 | Front 4-Pot Brembos | EBC Turbo Groove and Yellow stuff | HEL Lines | 15mm Spacers | 034 X-Brace | DK Tuning B8 Front Strut Brace | 034 Rear ARB | 034 Trans Mount Insert | Profusion Custom Exhaust | Xenonz Rear Diffuser |
    Jun 04 2007
    Exiled in Utah
    2012 A6 3.0t
    Daytona Grey S7
    Jun 07 2019
    London, UK
    2012 A6 3.0t
    Is that a CREC engine?
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Was there any noticeable difference power, drivability, gas mileage, before and after cleaning?
    I think that Audi claims, while it may look bad, it does not affect anything until it gets much much worse.
    I know the question will inevitably come back "How can it NOT affect anything?" and honestly, I don't know, but I do not recall seeing data points like either before/after cleaning dyno results or pre/post cleaning mpg figures for a few thousand miles.
    I recall if it got real bad on the NA RS4/RS5 V8 it caused misses, but AFAIK anyone who has gotten a cleaning on a 3.0T didn't mention misfires before the cleaning it was more just done because the S/C was off kinda thing.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Oct 18 2017
    NW Philly
    2012 is not a CREC, it only has one set of injectors.
    2016+ are CREC, and have dual injectors: thottle body injectors (helps clean backside of valves) and direct injectors (which don't).
    I'm not sure how it will look when it all gets opened up, since I do drive it hard, and everywhere all the time. Hopefully I can get some pictures.
    Nov 27 2015
    UK, West Berks
    FYI CREx went into production in Summer 2014. I don't know when it came to North America but certainly it was only in cars like the A6 and not in the S4 or S5.
    I have seen only a few CREx valve pics and so far all looked pretty clean in comparison to the older engines so I am under the impression that the dual injection is keeping the carbon low.
    But the more pics we can get the better.
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by Dippy View Post
    Came to the US for MY16; US Models C7.5 16+ have the CREC
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Oct 21 2021
    2019 A6 Prestige
    Quote Originally Posted by MattyMarkey View Post
    Yup, along with the A8's and Q7's. Only 3 that got it from all the researching I've done.
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    This ⬆⬆
    Oct 18 2017
    NW Philly
    Car goes to Indy Thursday. If and when they open it up, I'll ask for photos.
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by Spitfire007 View Post
    When I had my oil BMW (N54) walnut blasted while other work was being performed, my Indy sent me photos. It wasn’t awful at about 100k miles, but it needed attention. Gas mileage increased and idle was nearly silent once the WB was done.
    That motor, however, was DI only. CREC isn’t and was supposed to avoid this issue. I’d definitely was to see whether the extra $$$$$ is sensible.
    Junior Member Two Rings regulartalldude's Avatar
    Jun 02 2021
    Philadelphia PA
    To confirm what some people have mentioned-
    CREC was an updated version of the 3.0T, one of the updates was going from 6 injectors to 12. Therefore, carbon buildup occurs at a much much slower rate. I had my blower off a few weeks ago (55k miles) and while there was some crud, it was extremely minimal compared to equivalent mileage first gen (CTUB) 3.0Ts. I also run ethanol for most of the spring and summer which is probably making it worse than it would be with just 93 octane.
    The odds that the issues you are experiencing are from carbon buildup are extremely slim. Unless you are seeing a loss of coolant, your PCV is probably fine. A lot of CREC cars have a PCV soft-code that can be seen when a full scan is completed from when the fuel-rail recall was completed but the unit itself is still fully functional.
    I am located in the Philly area and do a lot of maintenance work on my own cars and friends Audis- let me know if you ever need something done for a better price :)
    Edit: someone mentioned the coolant crossover pipe- this was another update on CREC that they replaced this plastic/rubber part with a metal one so it rarely fails anymore.
    2016 Audi A7 Prestige - Glacier White Metallic - Airlift 3P - IE S2+ DP welded clutch E45, HVF ZF8 TCU Tune - BC Forged 20x10 2-Piece wheels - JHM Race Pipes - AWE Touring Edition Exhaust Diamond Black - AWE Tuning S-Flo Intake - Garage Auto Sport Coolant Divorce Kit - Xpel XR Ceramic 5% rear, 20% front
    Oct 18 2017
    NW Philly
    Quote Originally Posted by regulartalldude View Post
    Thanks for the insight. I'm also in Philly.
    I don't think the car ever had a fuel rail recall done, and I've checked.
    Found my dipstick cap was gone after the Indy did an oil change....could that lead to issues? I think so.
    Hopefully it doesn't cause undue crankcase pressure issues leading to premature PCV or other failures.
    Honestly I don't know how much more money I want to throw at this car, but it's a bad time to trade in for something else...
    Needs brakes...
    Probably shocks and mounts...
    Oct 21 2021
    2019 A6 Prestige
    Needs brakes...
    A missing dipstick cap would absolutely throw a PCV code. Also, just remember no matter what car you purchase, you'll always need shocks and brakes. Wear items are wear items. Good luck.
    Mar 19 2019
    Toronto/Ontario
    Needs brakes...
    If you want to replace it with similar but newer, could you even find one? If I put my car up for sale and then looked to buy another, the best car I could find would probably be mine. Very slim pickings, even if I go to an A8.
    Oct 18 2017
    NW Philly
    Quote Originally Posted by WatchMeSpend View Post
    I'd much rather have a manual trans, so I'd be looking at other brands than Audi.
    That said, a Giulia Quad could persuade me to try another auto trans, but I'm really not happy with this one. Clunky, slow, makes the car surge when I don't want it to and doesn't downshift when I want or quickly enough in manual.
    I hate autos...
    Sep 16 2020
    West Michigan
    I hate autos...
    Did you do a TCU flash?
    The factory software is terrible.
    Jan 26 2019
    Tulsa
    Quote Originally Posted by sepheroth86 View Post
    It is a whole new beast with a TCU tune.
    Oct 18 2017
    NW Philly
    Not yet. I keep finding better places to put the $$$...
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    You should honestly run a bottle of techron in the tank every now and then. You will actually reap the full benefits because you have dual injection. It will help with carbon build up and help clean the other components of the fuel system
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Active Member Three Rings Thomas@TAI-VW's Avatar
    May 20 2005
    B8S4 Chariot of the CLODS
    Hawaii
    PCV code is probably from solenoid valve on that later model. You can replace it without SC removal if you cut the hardline and splice it into the plastic pipe coming out of PCV assembly.
    2012 S4,6MT. Steering wheel/4 rims & tires/seatbelts/windshield wipers/41 psi in front tires/40 psi in back tires/CD player/AC/sunroof/oil level=full/coolant=full/no CEL/glovebox/no car payments/dusty brakes/lowbeam/high beam/turn signals/small nick in the bumper from a stone about 1/16" in dia. about 4 " below the headlight/gas in tank/clutch-brake-gas pedals.
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    I am also in philly. Would you be willing to chat about DIY stuff? I’m tryna get my hands dirty and do some of the work myself. Just replaced by rear pads/rotors to try and fix my car wobble that didnt fix anything
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Quote Originally Posted by Mark.in.tulsa View Post
    I can confirm. A simple stage one and tcu tune woke my car right up and now its a monster
    Edit: everything is bone stock, no upgrades in engine parts or anything, just a tune and it was one of the best investments i did for my car
    Sent from my iPhone using Audizine Forum lv
    Jun 02 2021
    Philadelphia PA
    Quote Originally Posted by AudiInMyA7 View Post
    I can't promise all my attention but I'm always down to help other enthusiasts. Shoot me a dm
    Sent from my Pixel 6 Pro using Audizine Forum mobile app
