Results 1 to 40 of 66
    Established Member Two Rings ESSVIER's Avatar
    Dec 03 2021
    Portland
    Looking for a tune, but not enthusiastic about crackle overrun…
    Like the title says, I don’t want pops and bangs. I’m actually very pleased with the stock overrun setting.
    I can’t find any first hand opinions or information about the different tunes available compared to each other in regards to overrun crackle or burble.
    Anybody have any thoughts they can share? Much appreciated as always.
    Pics for clicks
    Apr 09 2022
    Tulsa, OK
    I had IE shut off the crackles in my tune, I dont like them either. Outside of the factory pops and farts in dynamic mode, I dont have any noises.
    2018 Audi S4 - 10.2@133 full weight - IE Tuned!
    Instagram - TulsaMike4
    YouTube - TuksonMike
    IE stage 3 tune on E70 * Pure 750 Turbo * Carbnlab Downpipe and intake tube with modded stock air box / BMS Filter * ECS Post Throttle Body Charge Pipes * ECS Valved Exhaust system * Wagner Intercooler and Charge Pipes * APR HPFP with RS Injectors * Methanol Injection system with AEM Controller * CTS Transmission Mount Insert * Vossen HF5 20x9 with 265/30/20 Michelin PS4S
    Jul 12 2016
    Gardiner/NY/US
    I am on IE Tune. Stage 1 had no difference that I could tell.
    Stage 3 has a ton, but you can use the Individual setting, set everything to sport except Engine Sound, and it acts the same as Dynamic minus the burbles.
    B9 S5 SB - IE ECU/TCU Stage III - IE FMIC
    AWE Touring Exhaust - Roc Euro Intake
    Pure750 - IE Turbo Inlet - 034 HPFP
    Senior Member Two Rings MGZ's Avatar
    Apr 23 2020
    SoFlo
    IE would be a great choice as you can turn your crackles off in Comfort, Individual, Auto. Driving settings
    Aug 26 2017
    Tinley Park, IL
    I recall IE offering no sounds at all option as well as selectable on stage 2+ tunes. 034’s more of a burble on stage 1 (think OEM doubled) while IE is pretty obnoxious. It’s really obnoxious actually.
    IE or 034 e85 on any given day | 034 Stage 2 TCU
    Dec 03 2021
    Portland
    Quote Originally Posted by TulsaMike4 View Post
    Ok that’s what I’m talking about. What stage are you running?
    Administrator Three Rings oesman's Avatar
    Oct 08 2016
    Houston
    One thing to point out is that the crackles will definitely depend on other exhaust modifications too. Like stock cat and exhaust haven't result in massive pops and bangs on stage 1 tunes that I tried (EPL & 034). There are a bit more but not a crazy sound volume compared to factory crackles. If you go stage 3 with a bigger turbo, a race cat, and an aftermarket exhaust then they can be quite loud and sound like gunshots a bit with my 034 Stage 3. I don't mind them though, but I can see how some people would not like them.
    I've got some sound clips here at (11 minute mark) of stock exhaust (at the time on EPL Stage 2) vs. x-pipe on same tune.
    Oct 03 2020
    San Diego/CA/USA
    I know tuners vary their pops and bang tunes. I think it has to do with ignition timing and dumping fuel off throttle to create a rich condition. I'd honestly prefer to have this completely off or stock. It's mild with 034, but not something I want to keep. With Accessport and hopefully DS1 in the future tuners will offer OTS where you can turn burbles off or on when selecting their OTS tunes similar to how the A3/GTI/Golf R platform has it currently.
    Established Member Two Rings Quimicax's Avatar
    Oct 15 2022
    Dominican Republic
    IE Best Option
    Dec 03 2021
    Portland
    I should note that I have a CTS catted downpipe installed and front resonators deleted.
    Thank you guys for the replies. I’ve been watching videos of people with these tunes and I think they’re maybe not as bad as I thought? My ex had IE on her Mk6 GTI and it burbled the entire time you were decelerating. I thought perhaps the B9.5 tune would be the same.
    Oct 08 2016
    Houston
    Quote Originally Posted by ESSVIER View Post
    It definitely doesn't burble the entire decel. With tunes its maybe a little longer than stock, but main thing is it gets more pronounced and then the more you modify the exhaust/cat it gets louder.
    Jan 16 2007
    Who doesn't enjoy sounding like a shootout at the OK Corral when coming to a stop in bumper to bumper traffic? Only reason I haven't gotten a tune yet is because of the pops. If the IE tune retains the OEM sound, I may have run out of excuses
    Oct 08 2016
    Houston
    Quote Originally Posted by jtdbsr View Post
    It doesn't do that coming to a stop unless you're sitting there revving up and letting off the throttle to do it on purpose. Especially in bumper to bumper traffic. It does it when downshifting to engine brake or when decelerating rapidly from a higher rpms by letting off the throttle, not just coasting to a stop or moving around in bumper to bumper traffic. You'd have to be doing it on purpose, like going into manual mode while in sport, then staying in 1st gear and just using that to accelerate without upshifting which will build enough revvs to pop when you let off. Also could just use comfort mode in bumper to bumper traffic, no room to enjoy sport mode anyway. The conditions for it to do it are pretty much the same as stock sport mode, just more pronounced and if the exhaust is modified then it's a lot louder.
    Dec 03 2021
    Portland
    Ended up pulling the trigger on the IE Stage 2 like 30 minutes ago. It’s 20% off right now. Hard to say no! And yeah it doesn’t happen in any mode but dynamic so, only OK Corral when specifically requested. I’m hoping it’s not too much. Time will tell.
    Jan 16 2007
    Quote Originally Posted by oesman View Post
    And that is exactly what happens once a certain IQ range demographic gets a tune
    Oct 08 2016
    Houston
    Sure, but I'm assuming you don't feel the need to do that right? So not sure what the problem is as far as getting a tune. If you don't like them at all that's a different point, just sounded like you didn't like the idea of having to always hear them in traffic on your car.
    Jan 16 2007
    I don't want my car to pop and definitely do not want to listen to others popping while stuck in traffic. I don't want anything more than the OEM burble under any conditions though. Sometimes I do put the car into manual mode in traffic so I don't have to brake/throttle all the time and that means higher RPMs to decel from. If that produces pops, it's a no go
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    If youre in traffic, just go into comfort mode/manual and you won't hear a damn thing. Youre over thinking this. Its not like gunshots, its very tamed in a sense to where even if you have just a front resonator delete they're just like slightly more exaggerated than stock.
    Sounds like you dont want to be "obnoxious" so that tells me you won't be changing the downpipes or installing a full exhaust? Most tuners have a 30 day trial. Give it a go and if its just such a big deal then return it!
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Apr 23 2020
    SoFlo
    i have mine set at 1.8sec
    '18 S4 | IE Stage 3+ TrueFlex | IE Stage 3 TCU | TTE810 | RS Injectors | CTS Test Pipe | IE Inlet Pipe | CTS Intake | APR HPFP | 034 Engine Mounts | Wagner IC | Wagner Charge Pipe | JXB Driveshaft | 034 Trans Mount | ECS Diff Mount | Fuel-It E85 Sensor | KW HAS Kit | 034 Rear Sway Bar | CTS Strut Brace | ECS SS Brake Lines | Aodhan AFF7 | 4Bar | Sport Diff | Quattro Grill | ECS Spoiler/Diffuser/Font Lip/Grill Accent | Inozetek Liquid Molten Copper |
    Apr 23 2020
    SoFlo
    Quote Originally Posted by awdconnor View Post
    some people really overthink, knowing they can turn it off. They still make a scene out of it. It's ridiculous
    Junior Member Two Rings
    Oct 30 2020
    North NJ
    Quote Originally Posted by MGZ View Post
    How did you have the duration adjusted?
    Thanks
    Feb 02 2021
    San Diego
    I think I just have a bias against pops since race cars/supercars don't pop (on the regular) and you hear the tone of the engine. My s4 pops and mostly burbled every once in a while and I loved it. It's very racecar when it's rare and random :) The 034 tune is absolutely incredible in comfort, but in dynamic, (with my high flow cat) will pop 5+ times every downshift. I'll admit I definitely liked it at first but after a while I just wanted to hear the beautiful engine note running through the range. Now it reminds me of those wooden sound-makers I would spin and play with as a kid
    Oct 08 2016
    Houston
    Quote Originally Posted by Sebastian Tu View Post
    I mean it depends on the racecar/supercar.
    Jan 16 2007
    If this was directed at me.. turning it off via putting the car in comfort mode will not work for me as I drive in individual mode at all times. This mode is configured with sport mode across the board with the engine sound in quiet mode in addition to the sound generator volume turned down to 0 via coding. I'm looking for a tune that does not pop and maintains OEM sound characteristics.
    Only want a stage 1 tune, no exhaust. Trials work when you are committed to get a tune no matter what and is just a question of from which tuner since once you flash, its TD1 even if you end up returning the tune. Imagine getting a TD1 while not tuned.
    Jun 07 2016
    Portland, Oregon
    If youre worried about TD1, dont tune the car.
    Jan 16 2007
    Holy shit, forget I said anything
    Jun 07 2016
    Portland, Oregon
    Im not trying to fight with you, im merely making observations based off the things you've said in this post. The tune even in comfort mode is MILES better than stock. But because you brought up TD1, it shows that its in the back of your mind. Maybe its better for you
    to wait until your warranty is up, and by then MAYBE they will make a non-burble map you can flash to.
    Feb 02 2021
    San Diego
    I know what you mean, but I think you also know what I mean lol. some will as well (especially newer ones). The f1 video is still kinda what I would like (2-3 like our stock tunes did), mine is a lot more. Ooh you know what would if anything be a really cool sound is the f1 blown diffuser! (a great sound I wish f1 cars still had) and that aventador is tuned for sure
    Dec 03 2021
    Portland
    I like to think that our cars have F1 engines because the turbo is in the middle… you won’t change my mind
    Jan 01 2018
    Idaho Panhandle
    I'm with you on all this. I hear you don't want to get tuned, decide it's not what you want but then forfeit the not tuned ECU status. With all the other advances in giving us tune options, it's a shame that stock sound is not one of them.
    I think the only way through this (if you want a tune bad enough to compromise) is to make the best guess which is the least offensive tune and give it a 30 day trial.
    I went APR when there were no other choices. I liked that they kept the stock sound with v1.0. I'm not sure if the current version changed that. It's been too long since I was on stock. No one here talks APR, since it's not tune at home, but you might give them a call and get a definitive answer from them.
    2018 SQ5 Prestige, S-Sport, Dynamic Steering, APR 91 Stage 1 Tune
    Dec 03 2021
    Portland
    UPDATE:
    I’ve had the IE stage 2 91 octane installed since yesterday.
    The crackles/burbles/farts whatever you want to call them are not annoying.
    I think they sound the same as stock but 2 to 2.25 times the duration.
    I think, like many have said, that the fart acoustics are determined by your exhaust setup.
    Overall I’m very happy. The thing pulls like a damn freight train now.
    Oct 08 2016
    Houston
    UPDATE:
    Glad you're happy with the setup! The exhaust as you found is the real culprit for volume of the burbles/crackles and what causes them to start sounding like gunshots.
    Nov 17 2021
    hudson, oh
    Quote Originally Posted by spacecase View Post
    Other than just being an obnoxious and silly sound what is the benefit or drawback in the pops & bangs? Isn't it just fuel that isn't spent correctly and gets burned up in the pipes? I hate the noise.
    Apr 23 2020
    SoFlo
    Put it in individual and put engine sound to comfort. There you go.
    Apr 23 2020
    SoFlo
    UPDATE:
    It's 2.55 to be exact
    - - - Updated - - -
    Quote Originally Posted by Druggedpolak View Post
    Thanks
    I'm a beta tester
    Senior Member Two Rings Goonz's Avatar
    Dec 06 2019
    Boston, MA
    Any feedback on APR tunes? Thinking about going that route as I'm not looking for anything crazy and will eventually upgrade my intercooler in the summer.
    '22 e-tron S Prestige
    SOLD '19 Audi S4 / GW/Magma / B-Optics / S-Line / B&O / Milltek CBE / 034 Rear Sway/Strut Brace/Mounts/Front UCL/LCL / 034 Stage 1/ APR PEX Intake / RS Grille / H&R Springs / Audi Blackline Taillights / Matrix LED Headlights
    Oct 15 2022
    Dominican Republic
    Quote Originally Posted by Goonz View Post
    IE / 034 Apr Is Very Outdate
    Oct 08 2016
    Houston
    Yea in 2023 i have no idea why you'd get APR.
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    Only reason I could see is that some dealers honor APR tunes and won't void warranty. Other than that, yea, no reason to choose APR.
    19' Glacier S4 Black Optics
    Oct 08 2016
    Houston
    Quote Originally Posted by FromS60toB61.8t View Post
    Yep, but also as I understand it it's still a 3rd party warranty so it's not really the factory warranty anyway. Not sure how great it is.
