Results 1 to 7 of 7
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Radiator Fan Running Constantly but Temp Gauge is at Middle point - codes inside
    Hey all,
    I'm a little perplexed by this as I would've thought it was a failed thermostat, however the temp gauge isn't really showing typically symptoms of a stuck thermostat. How often does the Coolant Temp Sensor actually fail?
    Here is the code dump.
    Thanks in advance for any insight!
    Code:
    6 Faults Found:
    8113 - Performance Malfunction in Cooling System
              P2181 00 [101] - -
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 130754 km
                        Date: 2023.03.13
                        Time: 15:29:09
                        Engine RPM: 2213.50 /min
                        Normed load value: 28.6 %
                        Vehicle speed: 111 km/h
                        Coolant temperature: 61 ∞C
                        Intake air temperature: 6 ∞C
                        Ambient air pressure: 990 mbar
                        Voltage terminal 30: 14.800 V
                        Unlearning counter according OBD: 40
    33160 - Engine Coolant Temperature Sensor 3
              P01E4 00 [096] - Implausible Signal
              Intermittent - Not Confirmed - Tested Since Memory Clear
    30226 - Engine Temperature too Low
              P3081 00 [096] - -
    11786 - Sensor for Cylinder Head Temperature
              P017B 00 [096] - Implausible Signal
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 130756 km
                        Date: 2023.03.13
                        Time: 15:30:49
                        Engine RPM: 2117.50 /min
                        Normed load value: 45.5 %
                        Vehicle speed: 89 km/h
                        Coolant temperature: 58 ∞C
                        Intake air temperature: 2 ∞C
                        Voltage terminal 30: 14.720 V
                        Unlearning counter according OBD: 39
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    15851 - Performance Malfunction in Cooling System
              P2181 00 [101] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 130754 km
                        Date: 2023.03.13
                        Time: 15:29:09
                        Engine RPM: 2223.50 /min
                        Normed load value: 27.8 %
    11510 - EVAP System Temp Sensor
              P2025 00 [237] - Implausible Signal
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 130777 km
                        Date: 2023.03.13
                        Time: 18:52:48
                        Engine RPM: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 255 km/h
                        Coolant temperature: 64 ∞C
                        Voltage terminal 30: 12.120 V
                        Engine status: COENG_FINISH
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
    Readiness: 0000 0000
    Lurker
    Jul 16 2018
    Atlanta
    You need to monitor the actual coolant temp sensors and see what they are actually doing.
    G62 is the coolant temp sensor on the cylinder head. You can unplug the harness and test the resistance across the sensor pins, should be "2,250 Ω (+/- 750 @ approx. 20° C)".
    G83 is the coolant temp sensor at radiator outlet. You can test it the same as the G62.
    The P2025 likely means the temp is more than 25°C different from the coolant temp or the intake temp. So that's probably just a byproduct.
    vehicle speed
    outside air temp
    coolant temp (G62 measured)
    coolant temp at radiator outlet (G83 measured)
    coolant temp at engine output specified (G62 expected)
    coolant temp at radiator outlet specified (G83 expected)
    coolant temp diff between engine and radiator
    temp sensor for engine temp management: target
    engine oil temp
    oil temp sensor 2
    calculated oil temp
    That's 12 values (all VCDS lets you log at one time). So I'd log that and then process the data in Excel to see where the illogical occurs. If a sensor seems disconnected from the rest, maybe an issue with it. If the temp just never seems to come up to target, maybe a thermostat issue. The B9.0 electrically managed thermostat is definitely not a poster child for reliability.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Awesome. Appreciate all the detailed info.
    To make matters worse - the symptoms and CEL all disappeared today.
    I’ll log the all of the above when it returns.
    Jul 16 2018
    Atlanta
    Yeah, bad case would be a wiring issue or a flaky sensor so it's errant manner is random.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Almost looks like all the temp sensors lost the common +5V reference voltage.......open circuit or short circuit wiring issue?
    All 5 temp sensors failing at the same time is not likely.
    SMAC770: What the hell is an "EVAP" Temperature sensor???
    Jul 16 2018
    Atlanta
    The J909 fuel tank leak detection control module has a temp sensor in it, to be used in conjunction with the G400 fuel tank pressure sensor, for assessing fuel tank state. The J909 replaces the old V144 leak detection pump system. Just like the TPMS sensors read both temp and pressure inside the tire, the J909 needs both the temp and pressure inside the tank to really compute accurately.
    Some background info on the config:
    https://static.nhtsa.gov/odi/tsbs/20...21304-9999.pdf
    Some more information on the J909 system:
    https://forums.ross-tech.com/index.p...92/post-151429
    So this sensor is built into the J909 and is in the fuel tank area, it gets 12v from a fuse in the left rear fuse block. Independent of anything in the engine bay.
    Sep 24 2014
    Central NJ
    Interesting, they added a temp sensor to get rid of the motorized vacuum pump.
    Thanks for the info!
