Results 1 to 4 of 4
    Veteran Member Three Rings 3 bar's Avatar
    16 SQ5, 14 A7 Tdi, 91 Corrado, 02 Passat wagon, 99.5 A4 TQM
    Greensboro NC
    Who’s done an auto to manual swap? Is a manual subframe needed for an O1X?
    So I just realized after pulling my motor and trans that the auto transmission subframe is setup like my B5.5 Passat where the transmission is suspended by two ears. The b6/b7 manual has no provisions for side mounts and relies on one center mount with a aluminum double hump support. I’m wondering if I can keep the subframe or do I have to change it when doing a manual conversion?
    2004 Atlas Grey A4 Avant
    1999.5 Volcano Black Audi A4 1.8TQM
    2002 VW Passat wagon 1.8t 5 speed
    1991 VW Corrado 1.8t w/matching trailer Waterfest 03/04 winner (show)
    1980 Chrysler Cordoba LS 371ci 450hp 12.68(go)
    Greensboro NC
    Went to yard today and found out that the subframe is different gonna re-examine the subframe and determine if I can use the ears of an B5 O1A trans on an 01x trans mission and mount it to the existing auto crossmember. If not I will then cut the ears off the subframe and mount the b6 crossmember in place.
    Jan 24 2010
    Paramus,NJ USA
    I would just install a cross brace. I will be doing the same swap on my avant. I think cut the ears off and call it a day, but I am curious as I never see it mentioned if its really needed.
    Ziddy Autowerks
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    I haven't been on AZ in years, but randomly got a thread update for another old thread in my email and came back to the B6 forum, saw your question.
    Granted, it's been over a decade when I did the swap, but when did a swap from tip to an 01A, I did use the manual trans subframe. You can check out some of the pictures and my progress here: http://forums.bigskyeuro.com/viewtop...=3235&start=60
    Oh and here on AZ too: https://www.audizine.com/forum/showt...o-lots-o-parts
    Do you have a full parts car available? There's a lot of parts you'll need that you don't think you need, until you need them lol.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
