Results 1 to 19 of 19
    Junior Member One Ring
    Sep 19 2015
    Venetia/McMurray, PA
    How does the A7 determine estimated fuel range?
    On the highway in VA I may get as high as 32mpg. Around town in PA it drops into the teens. Starting from PA, before a trip I add enough fuel to get to VA where prices are lower. I usually figure about 25mpg starting with the estimated ange, but it seems to have a random effect on the updated estimated range.
    2016 Audi A7
    2021 Porsche GT4
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    The car will estimate the fuel remaining in the tank and apply the average recent fuel economy to guess at the distance to end of tank. I want to say it takes a sample of the last 20 30 minutes of driving.
    Highway I can get a bit past 400 miles to where I feel comfortable to extend my range to for a pit stop. It will go more than that but my bladder does not always agree with traveling further. Distance between pit stops drops when I have more than just my bladder to deal with.
    On the highway the car is going at a constant speed with a constant fuel consumption. Around town it is normal for the fuel economy to drop as you accelerate, decelerate, and stop to idle at stop signs and stop lights. The lighter on the go pedal you can be the higher your estimated fuel economy can be around town.
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    That DTE estimate is always going to be wrong. Best to observe personal tank avg and go with that.
    18 S6
    Sep 19 2015
    Depending on how good the initial estimate is my 25mpg rough rule-of-thumb has worked pretty well. I was just hoping for something a little better. If the initial estimate is too high I may have to splash-and-dash in WVA but usually I'm okay.
    This is mostly a game for me, gas enough to get from PA to Winchester, gas enough to get from Winchester to Waynesboro and then top up based on Gas Buddy. My wife thinks I'm nuts. I actually came into Waynesboro once with 20 mile range on the clock, which is better than running out on I-64!
    I also top up in Winchester heading North. If I don't use the car much in PA I usually have almost enough gas to get back to Winchester. Fun.
    2016 Audi A7
    2021 Porsche GT4
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by rbpeirce View Post
    Terrain also makes a difference. I can imagine in several years mapping and traffic monitoring software will be sufficiently improved so that a routing will also predict fuel use for speed limit driving.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Poorly.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Quote Originally Posted by GilliamOS View Post
    Poorly.
    I pulled off highway into Costco two weeks ago. Filled 17 ish gallons when the car estimated 10 miles remaining. That suggests Audi is conservative but I’ll NEVER go that low of estimated miles remaining!!!!
    I’d prefer to fill at about 30 remaining - or 1.5 gallons…
    Nov 27 2018
    Valparaiso, IN
    I’d say it’s about 1.5 to 2 gallons remaining in the tank when the low fuel chime kicks in and asks if you want to navigate to the nearest gas station. Now our old Jeep, when the low fuel light comes on that ****** was on fumes. Had it come on once and I drove about 20 miles to get off the highway to a gas station. I put 14.7 gallons in a 14.5 gallon tank.
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by JWebb_C7_Comp View Post
    In another AZ thread a comment was made about a pump within the tank that uses the surrounding fuel as a "heat sump". The suggestion was that letting the fuel level get too low would cause that pump to run hot, shortening its life.
    Nov 27 2018
    Valparaiso, IN
    Quote Originally Posted by Alabama View Post
    I have read that statement many times however I have been driving since 1984 now and have routinely driven may all of my cars to the point that I fill up close to E. In 39 years of driving now I have never burned up a fuel pump from it. In all this time I have only changed 1 pump that actually quit and it turned out to be a broken wire. Another pump broke a fitting on the connection line.
    Sep 19 2015
    Quote Originally Posted by Valpo A7 View Post
    That sounds about right. I normally see about 40mi range left, give or take.
    2016 Audi A7
    2021 Porsche GT4
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Likewise, I've never had a pump fail; maybe just lucky. Up north the advice was to keep the tank relatively full in the winter to minimize water condensation and possible icing.
    Junior Member Two Rings Dave4501's Avatar
    Dec 11 2018
    2014 A7
    Chattanooga, TN
    When I fill my A7, it tells me I have a 500 mile range which is way higher than actual. So, the estimate seems to be a bit too optimistically calculated.
    I would guess I have about 2 gallons left when my low level light comes on. I can easily go 40 miles without much concern.
    Aug 14 2019
    Tampa
    Exactly my experience as well.
    18 S6
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    i live in the north and condensation is none issue with fuel injection it just shoves it thru not like carb cars. I have never had any issues BUT i'm also the guy that normally tries to fill t 1/4 tank but doesn't always happen
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Mar 12 2023
    UAE
    default avg consumption estimates are done based on 15 mins window, you can code it to be longer (20, 30, 45min). Based on my observation, the remaining distance is measured by taking the last avg estimate and current fuel amount, then rounding it up to full 10s (kms in my case, but I don't expect it is different for miles)
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    My tank always says i get 420 (giggity) - 450 a tank when full but i barely ever see above 300. That shit is dead wrong and idrk how it guesstimates DTE
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
    Mar 12 2023
    UAE
    Quote Originally Posted by AudiInMyA7 View Post
    remember that the estimate accounts for all the tank's volume, and you usually refuel when 10l+ (or 3+ gallons) are still there, hence you never reach the estimated value. These numbers are pretty accurate when doing highway miles, but the minute you get in a traffic, its accuracy become like becomes like reading tea leaves to predict the future...
    Sep 19 2015
    Mine is actually pretty accurate. My problem is after driving around town for a couple of weeks I take a 315 mile trip and have to decide how much high price fuel to buy to get to the low price fuel [Gas Buddy]. My approach has been to take the posted range and allow about 25 more miles for each gallon I add. This always over-estimates how much fuel I need but I can't figure what to do about it so I don't.
    2016 Audi A7
    2021 Porsche GT4
