Results 1 to 8 of 8
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    Strut mount socket?
    I'm in the middle of trying to track down a clunk in the right rear suspension. Does anyone know what socket you're supposed to use to get this strut mount off? With the wiring/harness you can't use a traditional strut mount socket. Am I missing something simple?
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    May not be the right size, but it would look something like this.
    https://www.ecstuning.com/b-schwaben...yABEgLc-vD_BwE
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Fry Sauce, UT
    Quote Originally Posted by gk1 View Post
    That's just a normal strut socket and won't work. The issue here is the wiring and harness coming out the top of the strut. I think I'm going to have to de-pin the connector to be able to get it apart.
    - Steve
    NKAWTG
    Sep 16 2020
    West Michigan
    Looks like you need something like an O2 sensor socket.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Junior Member Two Rings
    Jan 11 2013
    SF Bay Are
    Been looking into this to do my own. The Audi service manual (not easy to post the graphic, sorry) calls out a couple of tools:
    - T10001/3 - a passthrough socket for the outer nut. Unfortunately out-of-stock on the SnapOn manufacturer tool store: https://audi.snapon.com/SpecialTools...temId=17440108
    - 1332/7 - torque wrench adapter for the socket
    - T40255 - 9 mm holder for the shaft, has wrench flats on the top. Available on the SnapOn manufacturer store: https://vw.snapon.com/SpecialToolsDe...temid=36840108
    The procedure says to remove the protective boot and housing connector from the wire so you can pass it through the socket.
    What size is the outer nut? FCP Euro has strut nut sockets in a couple of different sizes, here's a 19mm: https://www.fcpeuro.com/products/19m...t-cta-3039x04; they have other sizes from 16-24mm.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    I used this for my rear shocks on my A7.
    https://www.fcpeuro.com/products/17m...et-cta-3039x02
    Fry Sauce, UT
    Quote Originally Posted by theskipper View Post
    I de-pinned the connector but totally destroyed the purple locking tab in the process so I need to pick one up tomorrow. The part number is 1J0 973 802.
    I ended up running to Harbor Freight and picking up an offset box wrench kit. The top nut is 18mm. I broke the nut loose with just the 18mm and then used a 9mm open-ended wrench on the top of the strut to hold it in place while removing the nut the rest of the way.
    I realized I need to order a different strut mount as well. 4G0513353D and 4G0513353C are stamped on my original mount and I ordered 4G0513353D. However, the "D" part number is only correct if you don't have air suspension/dynamic ride control. 4G0513353C has a larger pass-through to accommodate the dynamic strut.
    - Steve
    NKAWTG
    Senior Member Three Rings mrdouble99's Avatar
    Mar 31 2018
    Montreal
    i had this knock in the right rear pasenger side on my 2015 and now on my 2018 S6
    If you fix it, plz let us know :)
    Mythos Black Metallic 2018 Audi S6 current
    Moonlight blue 2015 Audi S6 sold
