Results 1 to 11 of 11
    Junior Member Two Rings
    Feb 25 2023
    Burbank, CA.
    Lowering links vs. computer lowering
    Hi
    Considering lowering my 2018 SQ5 using lowering links. I have the air suspension. Called my local shop and they advised that they can actually lower the SQ5 using the computer and not needing the lower links.
    Has anyone out there done this? I would think the ride may be rough if the air suspension is overridden using the computer.
    Thank you
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    I would side with the computer adjustment. You can dial in exactly how you would like the ride height to be.
    Most of your aftermarket links are fixed. So one lower height, and done.
    Veteran Member Three Rings chrisdazzo's Avatar
    Aug 11 2015
    RAV4 Limited
    Mountains, CO
    Don't the lowering links just lower the height on all the ADS modes? It doesn't force you into a single height iirc. And ~$200 vs. $1350.
    '21 Ultra Blue x Black Nappa ▉SQ5
    Prem+ : S Sport : Black Optics : Carbon Atlas
    21" Black Optic Wheels : B&O Audio : S Beam
    034 Res-X Res Delete + X-Pipe : IE Polymer Intake
    12.5/15mm Spacers : 034 Trans Mount Insert
    35% Ceramic Tint : 3M Front PPF
    [_SQZME] : Previously: MKV Jetta 2.5, B8.5 A5, 8V S3, B9 A5 SB
    Feb 25 2023
    Burbank, CA.
    The lowering links would be $100 for parts plus labor/dial in. Computer override would be $200 all in
    The cost is sub what in the ball park but trying to figure out the best way to go. If the computer lowering is available, then wondering why more SQ5 owners haven’t gone this route?
    Aug 14 2015
    So. Cal
    Quote Originally Posted by Dkiesmith2411 View Post
    Computer lowering doesn't lower enough. For me at least.
    Instagram: sqfunf
    2024 Rivian R1S
    2021 SQ5 - Ultra Blue
    2016 Focus RS
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    If I were going to bother spending the money for air suspension I’d go with a CETE module to get the widest range of adjustability.
    iain
    Jul 06 2020
    wilmington, N.C.
    Would someone mind explaining what has to be done to the computerand what it allows you to do after. Thank you for any replies.
    2016 S3--Apr stage 2,APR downpipe, APR Trans tune, 034 springs and rear sway bar
    Aug 14 2015
    So. Cal
    For me it was $200 vs. $1349. I set it on Dynamic 99.969% of the time. Height is perfect and no need for all mode adjustability. Offroad mode is still high enough to clear most obstacles.
    Instagram: sqfunf
    2024 Rivian R1S
    2016 Focus RS
    Aug 14 2015
    So. Cal
    Quote Originally Posted by ghall View Post
    Explanation within the thread:
    https://www.audizine.com/forum/showt...uspension-Drop
    Instagram: sqfunf
    2024 Rivian R1S
    2016 Focus RS
    Aug 11 2015
    RAV4 Limited
    Mountains, CO
    Interesting, didn’t know the suspension could be programmed down once via computer instead of buying the CETE. It seems that method (above this post) lowers the suspension to a “new” factory point that the car thinks is default, then the drive modes adjust as normal from there? That’s pretty badass for the price.
    Jul 16 2020
    Bay Area CA
    Hi
    Thank you
    I had mine done, the max they could do was -20mm without errors. They said it varies by car, not just year. I like the height (still don't hit parking curbs) and 034's track testing said their optimal height for performance driving was -15mm, so I don't see a reason to change. As you lower air suspension, you effectively reduce the spring rate, so there's a tipping point between ride height and suspension stiffness.
    Sent from my SM-G991U using Audizine Forum mobile app
