I just replaced my battery with a Duracell Platinum H8 AGM battery from Autozone and I'm having a hard time reprograming the car because the battery does not have a new BEM code since its not OEM. I understand that people say that you don't have to recode, etc. but since it is a different type of battery(liquid to AGM) from what was previously in the car I feel like it is necessary. When I first installed the battery the car started right up, faster than it ever has but after that its gone back to taking a couple cranks to start. Battery voltage on my OBDEleven app shows around 13.8V to 14.9V while driving but if I put the car in accessory power mode(engine not running) it drops to 11.8V. Is this normal? Also, I tried changing one number of the serial number from the old battery in the coding menu but the battery health is still showing 0%. To those of you who have replaced your battery with a non-Audi battery, what did you do? Is the long cranking normal? I don't live in a cold area, the coldest it gets is around 55F. Seems like the car has a bit of a rough idle too, not sure if that's from low battery health. No warning lights or codes.
