Results 1 to 5 of 5
    Feb 11 2023
    Eldersburg, MD
    Flashing "speed limit" light in HUD?
    Hi Everyone....brand new to the forum and in the future, maybe a used 2019 S4 Prestige...only 13K miles on her.
    I test drove the car today...very nice....but one thing that was driving me crazy was the speed limit "sign" that is in the HUD and flashes if you exceed the stated speed limit by a few miles an hour.
    I'm guessing you can remove this...but I wanted to confirm with those more knowledgeable than I.
    I know you can adjust/remove the speed limit warning feature (set it to 90mph, etc.)....
    ...but I'm referring to the flashing that happens when you exceed the stated speed limit of the road you are on at the time
    (Speed limit may be 40mph....and when you go 45, the speed limit "sign" flashes, etc.)
    From an overall perspective, should I look for anything specific if I go test drive the car again?
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    Yes. That can be shut off in one of the MMI menus. It blinks when you exceed 10 miles over the limit.
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Controlled via the MMI:
    > Select in the Infotainment system: [MENU] button
    > Vehicle > left control button > Driver assistance
    > Speed warning> Traffic sign based warning.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Feb 11 2023
    Eldersburg, MD
    Thanks!...I figured you could remove it :)....Now just need to decide if I want to pull the trigger on a 2019 S4 Pristige or not...
    Veteran Member Three Rings Longtallsally's Avatar
    May 10 2019
    Bikes and 4x4s
    Der Vaterland
    Check the production date to verify it has the updated rocker arm design that seem to be going around. I don’t know what it is, but a little searching and you can find the cutoff.
    Mine is driven like a grandpa 95% of the time sadly, but the platform really seems very stout and has minimal issues on the whole.
    ‘19 Prestige with all the toys (diff, steering, etc.)
