Results 1 to 37 of 37
    Junior Member One Ring
    Jul 07 2019
    TX
    Front control arm bushings bad at 49k miles - $4500 to replace?
    I've got a 2016 S6 with 49k miles. The dealer says my front control arm bushings are dry rotting / cracking? And quoted $4500 to replace (re-using control arms and replacing bushings only).
    I don't drive my car hard so I'm a bit surprised they are needing replacement and also the high cost. I'm not noticing any degradation in handling or any odd noises.
    Is this kind of wear normal? And is that price reasonable?
    Is it difficult to DIY? I'd have to bring to a shop with a press.
    Dec 08 2018
    Northeast
    LOL!!! Yeah, go to Indie shop.
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Control arm wear is normal on these heavy cars. It’s not all about the miles, but more so the length of time/years. The bushing material Audi used just cracks and gets brittle over time. Since you don’t have any noises, that just means it’s not metal-on-metal.
    The parts are right around $1000. It does not make sense just to do the bushing themselves. It’s still a fairly labor intensive job - there are a couple DIY’s on the forum.
    Def find an Indy shop, they’ll do it for half the cost.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    just replace the whole control arm, you can get them for cheap on rockauto.com or you can buy oem. Take it to an indy shop or mechanic and voila headache is gone. bushing wear is normal
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Oct 18 2017
    NW Philly
    I got a quote from my Indy to replace both for about $800. That's the whole arm AND bushing
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Quote Originally Posted by MattyMarkey View Post
    And then sometimes you get a car that is fine with stock suspension. My 2012 A7 has 226,300 miles on original equipment. I will be doing a deep dive inspection when the weather warms up to see how my stuff is doing though.
    Jun 19 2018
    NH
    Quote Originally Posted by Valpo A7 View Post
    You are certainly in the minority and a rare breed, or at least that A7 is lol. Might actually have something to do with the miles too - you certainly drive it, so it's not sitting around. We all know seals and certain rubber does not like to sit around for extended periods of time.
    9 year old car over here, with under 50k miles. Sat around for a lot of it's life for the first 6 years... my bushings are showing signs of failure
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    034 sells control arms with their upgraded street density bushings. Just go that route for around $800 in parts. Trusting a service tech to press bushings is a toss up. 50% chance they squeak like shit.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Jun 19 2018
    NH
    Quote Originally Posted by ericw. View Post
    ^ Route I plan on going; 034 that is.
    Established Member Two Rings RAUDIRS6's Avatar
    Dec 02 2013
    18 RS7P, 14 Q7 TDI
    Lusby, MD
    I did a full suspension replacement on my 03 RS6 when it was 9 years old. Most of that was 034 parts. I did it in a 1.5 car garage with basic tools. Took about a week.
    I did the same on my 04 S4, but it was 14 years old.
    When you're done, make sure you go to an indy shop for a proper aftermarket parts alignment.
    Sent from my SM-S908U using Tapatalk
    2018 RS7 Performance (Nardo)(DS1 Mod Stage 2, JHM TCU, ECS Intake/Inlets, CWA-100, ARM DP w/ HF Cats, ECS 2.75" Valved Exhaust, 40T E-Sensor w/Bypass & Lines, 034M HPFP, Forge BOVs, JHM T&D Inserts, 034M Tunnel Brace)
    2014 Q7 TDI (RSNav)
    2004 S4 Avant 6MT
    2003 RS6 (6MT Conversion Project)
    2002 Passat Wagon
    1998 Passat Sedan ($1250 Budget Build Project)
    2000 New Beetle
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    I don't like those odds.
    18 S6
    Senior Member Two Rings FourRingThing's Avatar
    Jun 17 2011
    Charleston, SC
    49K you still have 1000 miles of warranty.........
    give them hell
    2021 B9 S5, Black optics, Sorts Package, Black door handles, spoiler wrapped black, IE intake and inlet pipe, ECS Tuning strut tower support.
    (sold) 2012 C7 A6 3.0T Prestige, Innovation Package, 20" Sport Package.
    Jun 19 2018
    NH
    Quote Originally Posted by FourRingThing View Post
    give them hell
    Just 3yrs too late for that…
    Established Member Two Rings cuerna's Avatar
    Jun 23 2010
    Lubbock, Texas
    $4,500 is way too much.
    My control arms are shot, 2012 A6 3.0T Sport suspension.
    I am planning on buy them all from rockauto (Delphi) for about $450 and replace them on a Saturday when we get better weather.
    Audi A6 2012 3.0T
    BMW 330i 2006
    VW GLI MKV 2.0T
    Audi A4 B6 1.8T
    VW Golf MK4 2.0
    VW beetle 1995
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    I replaced my front suspension control arms with 034's density line control arms for significantly less than $4500. My stock control arm bushings were still 'good' but showing their wear on the track. You can not go wrong with 034's control arms.
    Here is the link for what I purchased which also included adjustable upper control arms. https://www.034motorsport.com/densit...a5-s5-rs5.html
    Here is the link for complete upper/lower control arms https://www.034motorsport.com/densit...a5-s5-rs5.html
    Here is the link for just the lower control arms https://www.034motorsport.com/densit...a5-s5-rs5.html
    When I replaced mine I had a noticeable improvement in my handling on the track as well as the street.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Jul 07 2019
    TX
    The service advisor warned me against getting non-oem replacement arms saying they would make noise. 034 arms look good but I don't want to risk squeaks and clunks. I'm not tracking my car so just want some OEM equivalent parts. Does anyone know who the OES is for the stock arms? Is it Lemfoerder or Meyle?
    I did find the DIY: https://www.audizine.com/forum/showt...ol-Arm-install
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Quote Originally Posted by braincell38 View Post
    Ok, but the OEM ones make noise too. Back in the day dealers were saying that synthetic oil blew up engines! Seriously a lot of the service advisors are flunkees and half a salesperson. The one time a stealership ever serviced my car, was because it wouldn't start and I was 500 ft from the entrance on Saturday. What did I get? A new starter I didn't need because the mechanic found a corroded wire, They washed my car and bragged about how clean it was but it is ceramic coated and I told them not to wash it. Then they left a greasy handprint on my roof liner when they pushed the car in. If I would have told them about it, they probably would have used an extractor on the roof liner to clean it, which will typically cause all the glue to release in a few years and the roof liner hangs down like a batman cape.
    Find a good indie and work the small repairs by yourself if you can.
    Veteran Member Four Rings digdah's Avatar
    Dec 11 2017
    DFW
    For $4500 I'll fly in, come pick up your vehicle, and return it with new bushings. Just don't ask for any receipts.
    Edit: I see you are also in TX so it may be a drive. Rest of the offer still stands.
    Dec 08 2018
    Northeast
    Of course they would. How else would they make money? If you want OEM then go on FCP buy OEM bring Indie shop and saved 3000.
    Nov 27 2018
    Valparaiso, IN
    There is no reason to use OEM only parts. Quality parts yes, OEM no.
    For the front rotors on the A7. OEM front rotors are $250 each last time I looked. You can get Zimmerman for $175 each, just not labeled as OEM….. but they actually are. Zimmerman makes the OEM rotor, you are just not paying the 4 ring surcharge.
    If you shop at FCP Euro you can typically get the OEM parts labeled in the original packaging without the 4 ring surcharge. There are many companies out there that sell quality non OEM parts that will perform as good and many times better than stock. Service guys will not acknowledge this because they get paid by Audi to sell and install Audi parts.
    Veteran Member Three Rings eurospek's Avatar
    Mar 15 2008
    Chicago
    Would bad bushings lead to inner tire wear on both sides? Alignment was done in summer as summer tires had the same bad wear.
    Jun 19 2018
    NH
    Quote Originally Posted by eurospek View Post
    For sure. Obviously not the only culprit. If your car is lowered, that could also cause it, if it hadn’t been aligned. Could be multiple factors, but bad bushings could put your alignment off
    Junior Member Two Rings Blackmagic88's Avatar
    Oct 24 2021
    1995 C36 AMG
    Tacoma WA
    Hey, I'm kind of in the same situation as you, my 2016 A6 7.5 has about 88,000 miles on it. Took my car in for an oli change last Monday, they told me I need my lower control arms replaced at least the bushings. I guess the dealership wants $2600 to replace it. Long story short I went to ecstuning.com and order their front control arm bushing kit for 850 bucks and I will have my indie mechanic put it in for another thousand. Still a lot of money but cheaper than the dealership.
    Hope that helps in anyway.
    https://www.ecstuning.com/b-034motor...-401-1045~034/
    If you're not first your last, remember that!!!
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    It's clear that I need to budget to replace my front control arm assemblies by end of this calendar year. Good thing I don't drive much these days.
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
    Oct 18 2017
    NW Philly
    Is there much that goes bad in the rear?
    I'm noticing that my 2016 rides harsher than it used to and waffles a bit more on the road. I need front lower arms, but apparently all else is ok on an 82000 mile car....which I doubt.
    Oct 26 2019
    Mid-Atlantic
    Quote Originally Posted by Spitfire007 View Post
    Audizine
    I don't recall any threads/comments about early failures to rear suspension. Just shocks eventually wearing out, which is normal for any vehicle.
    Oct 18 2017
    NW Philly
    With the really BAD Quattro rumble and vibrations, and assorted other little things, I dunno if I really wanna keep the car....so I might not bother throwing shocks at it....that said, still cheaper than a new car
    Oct 11 2011
    2018 A5 SB
    I have no noise from my 034 front suspension arms I put on about 3-4 years ago. So, the dealers noise argument is a poor one.
    Active Member One Ring omega_jeff's Avatar
    Nov 09 2022
    '15 RS7. '19 Q7, '10 AMG E63
    Bay Area
    Just another data point for you: My dealer quoted me $1,400 for just the lower control arms and $5,800 for motor mounts!!. I'm local to 034, so I went there and was quoted $1,900 for their Density Line complete front end control arm package incl. installation. Did the 034 motor mounts and transmission mount as well for $3,100.
    Oct 18 2017
    NW Philly
    Quote Originally Posted by omega_jeff View Post
    Aaaannnnnd: how does it feel now?
    Noticeable difference? Better than stock?
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    My first time through, I just got done with the front, new shocks and springs, took me about 10 hours working on and off throughout the day. I could probably do it again in 6 hours my second go. $850 for the control arms from 034, $60 for the additional tools (I could have probably rented the ball joint separator) and I was done. So what would dealer labor be on top of that? What is that like 15-20 hours they are billing? I didn't know WTF I was doing and got it done in less time.
    Also, I noticed one person said check rock auto. Normally I hit them up, and I was just going to throw stock stuff back in, but it was more expensive to get the stuff from rock auto, and most of the other kits were around $700-750 so I just bit the bullet and ordered the 034 stuff, along with the mount inserts for the trans/diff and motor mounts too.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Jun 19 2018
    NH
    Quote Originally Posted by Burkeomatic View Post
    All depends what the dealership labor rate is; I’d guess $200/hr +
    Genuine OEM parts are also pricey AF. Just one arm runs $350-600.
    Jul 07 2019
    TX
    How's the NVH with the 034 control arms? Any additional vibration or road noise? Squeaks?
    Nov 09 2022
    Bay Area
    I can't say if it's better/same as stock, but it's back to "normal." The front end feels solid, stable, proper. As for the motor and transmission mounts...kinda the same thing. It feels like the car is a bit smoother at idle, maybe shifts a bit more solid. Even though my motor mounts were shot and clunking at take-off and coming to a stop (shifting into 1st), the car didn't shake or vibrate in an obvious "the motor mounts are shot" kind of way. I'd love to say "hell yea!....these 034 upgrades rock!..they're the best!...my car does 8.0sec 1/4 miles now!!!" LOL! But for sure, the price, the quality, the 034 on-site experience; it's all good. Highly recommended.
    Dec 08 2018
    Northeast
    So now with my RS7 being at 83K, I bought the winterfest sale.
    For $765.
    The shop near me does Audi work. The owner actually owns many Audi. They quote me $950 but that's including the 034 inserts and rear sway as well.
    Jun 28 2019
    California
    Quote Originally Posted by WideSuppie View Post
    For $765.
    Thats a solid quote for labor on all of those arms and the sways
    IG:@stolens6
    Mar 18 2016
    Jacksonville, FL
    $4500 is beyond price gouging, predatory business and criminal larceny. To only change bushings, not a single control arm or tie rod, for whatever benefit they concocted in the fantasy world, as one of the biggest things that I have an incredibly short temper for. That’s more than a dealership would charge, and they typically charge 300–400% above “realistic”. Not sure if this is a dealership, but unless it’s under warranty and 100% free, with a loaner, I would never take my car to a dealership even if you set me on fire. If this is a local shop. I would plaster their name all over town in a very bad light. That is absolute horsesh*t. Unlike 99.9% of the things that make us curse Audi as loud as possible, but would never - ever - want to part ways with our beloved cars… As evident of everything we post in here trying to figure out how to fix, find, solve, diagnose, repair, re-create and somehow comprehend, as the undeniably most inspiring amazing thing Aldi has done is somehow hidden half of the technical factors, sizes, measurements, diameters, gauges and needs special tools just to change brake pads or Audi timing tool kit needed as whatever model you have will sputter, shutter almost shut off if if the cam shaft timing gear assembly is one billionth of a millimeter off. Lol. Compared to most things that are over engineer, over vacuum-sensitive, hyper-diagnostic required, incredibly quadruple-difficulty and a “no way in hell you’ll figure - or understand - the over-complication of an electrical system - even above our brothers from the Fatherland, Mercedes and BMW - and hell will even over complicate the wiring and electrical system of the British - the genius level simplicity, and I know that’s a reach, of the control and suspension system is relatively easy to replace on its own. HOWEVER…. The part that makes it difficult for so many of us is not really having the equipment to put ourselves in a better position to do the work. Whereas many American and Asian manufacturers might be a little easier to do ground level work, even though they are geometrical complexity, similar to that of a F-117 Nighthawk Stealth fighter based on faceting, their control arms are not uncommon to have six or eight points of contact and are incredibly intricate and where the slightest mechanical issue could possibly be devastating, Aldi is baffling Lee beautiful and simplistic - however amazingly effective - and a lot of cases especially like a lower rear control arm….A———->B. Bolt 1 and bolt 2. And a lot of them as long as you can be in a position for the leverage part, you don’t need to be a tenured mechanic. But it can be very difficult if you don’t have the means to raise or even position the vehicle to make it easier to work please. I can be a little bit more of a struggle and I can be a little bit more hard work.
