I was trying to remove the ball joints from the knuckle after loosening all related bolts and nuts.
I sprayed a good amount of WD-40 penetrating oil ahead of time. Then I used a ball joint separator on each ball joint. The one I borrowed from Autozone kept sliding off from the bolt and nut as I tightened the bolt. It was not wide enough I believe.
I also used a pickle fork on it with brutal hammering, but no prevail.
Do you guys have any suggestions? Feel free to ask about my removal technique since I might be missing something.
Thank you for reading.
