Looking for some help and to validate my thought process on my most recent pickup, 2007 a4 2.0t. Previous owner said “a camshaft bolt backed out” and said it made some bad noises and he shut it off. He pulled off the valve cover, hpfp, and cam chain cover then left it alone. I looked at it today and notice that the head of the bolt that holds the cam chain adjuster sprocket to the exhaust cam broke and the pin that aligns with the cam sheared off. The timing belt is still in tact and timed to the crank. So my thinking is, there should be no valve damage- the cam adjuster sheared which essentially de-linked the intake cam preventing it from opening valves and the exhaust valves continued to open in time with the crank. If my thoughts are correct, I should be able to get a new cam adjuster and reassemble right? Only other minor damage I noticed is a slight divet in the exhaust cam alignment notch that the adjuster pin sits in. Does it look bad enough to have to replace? I guess the real question is why would this thing shear in the first place? Any help is appreciated. Some pics taken in a small circular mirror, you can see the bolt still stuck in the cam.
