Results 1 to 11 of 11
    Aug 18 2020
    Sonoma, CA
    Do B8's still have timing belts?
    First time post on this forum and more familiar with 2.0 B7's. Do the B8's after 2009 with a 2.0 still use timing belts? The 3.2 and 3.0 V6 are a timing chain engine correct? Considering a move to a B8 platform but wondering what inherent issues they have compared to B7's. How are the 3.0's?
    How bout cam followers in the 2.0?
    Thanks
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Quote Originally Posted by tractoman View Post
    First time post on this forum and more familiar with 2.0 B7's. Do the B8's after 2009 with a 2.0 still use timing belts? The 3.2 V6 is a timing chain engine correct? Considering a move to a B8 platform but wondering what inherent issues they have compared to B7's.
    How bout cam followers?
    Thanks
    No
    Yes but a better one
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Nah the B8s use timing chains. I'd say most B8.0 have the updated tensioner though I'd still run the VIN to see if it had the recall done; B8.5s came with updated tensioner from factory. B8.0 and B8.5 have chains that stretch every 100k to 120k miles and need to be replaced. Not many talk about the balance shaft chains but a YouTuber NaptownTuner did show the balance shaft chains do stretch, just not at as drastic of a rate but still best to replace them while you're in there.
    The C7.0 3.0T (supercharged but whatever Audi) have cold start chain slap because it looses oil pressure while sitting. Nothing too major but if the slap lasts for more than (I think) 2 seconds then you need to replace tensioners. Have fun with that because the chain setup is on the REAR of the engine so its an engine out job. While you're in there you might as well do the chains and the whole shebang. C7.5 3.0Ts (or C7.0 that already had the tensioners replaced) don't have chain slap because the updated the tensioner.
    From what I hear, 3.0T is much more reliable and doesn't burn NEARLY as much oil as the 2.0T do (though it is still common just not like 1 qt/400 miles like the 2.0T) but when things do go wrong it's more expensive since its an Audi exclusive engine that has 2 more cylinders.
    As much as I love my allroad, I keep debating whether to get a C7.0 A6 with the 3.0T or saving some more dough to get a C7.5.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Jul 16 2018
    Atlanta
    B7 and before used EA113 4-cyl engines. B8 and after use EA888 4-cyl engines. More than a few differences between them, including the change from timing belt to timing chain and the change from a sliding tappet to a rolling tappet. There's plenty to find out there about the common issues of the "FSI" and "TSI" engines (btw, neither of those terms are correct, but they are what you'll find web pages using, incorrect or not).
    3.0T is an S model thing in the US, unless you want to look at B8.5 Q5. Has its issues too, and oil consumption was one early on till they made PCV changes. SAI carbon clogging is an issue. Doing chains is a suck job that requires removing the engine and transmission (workshop manual process is for the 3.0T and trans to be dropped as a unit, then separated).
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    There were revisions to the b8/b8.5 timing chain designs. Apparently the original version installed in both b8 and b8.5s were more prone to stretch than the updated version. Easy to tell by taking off the top timing cover and also check the timing chain tensioner version.
    Dec 04 2006
    Los Angeles, CA
    I wish!
    B8 2.0T QTip
    Jul 16 2018
    Atlanta
    Chain is better than belt. We have a set way to monitor and plan for chain replacement. Belt you just have to do because it'll just snap out of the blue one day. That no one understood chain state monitoring when the EA888 came out is not the technology's problem. That Audi used a poor design for the original tensioner has nothing to do with using a chain vs belt.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by AudiTLC View Post
    I wish!
    lol
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 04 2006
    Los Angeles, CA
    lol
    B8 2.0T QTip
    Feb 15 2016
    Cambridge,Ontario
    i have a B7 and B8 .. both high milers , the jury is still out...
    1976 Yamaha XS 360
    Senior Member Three Rings Seal1968's Avatar
    Apr 04 2015
    Ontario
    Timing belts are way easier for a DIYer than a chain, but, belts don't last near as long. My 2013 timing chain lasted to 280,000 kms with adaptation @ 5.5 or something when it got done. (car had the revised tensioner)
