Results 1 to 23 of 23
    Established Member Two Rings mrg_B8TFSi's Avatar
    Dec 24 2021
    Audi 2013 A4 Quattro B8, 6-sp man, Audi 1998 A6 Quattro C5, Ford F250 XL 5.4L 4x4
    Northeast PA
    Battery type help
    Hello I’m looking and I can’t seem to find any information as to the type of battery I have, and my battery is low and with the car sitting with suspension components upgrades I’d like to get my trickle charger on it but not sure if I should engage the “normal” or “AGM” mode for the charger? I have what I think is the original battery it’s a Varta 8K0 915 105 F but I can’t find anything as to if it’s a conventional battery or an AGM and if there is a difference in the charging mode when on the 2amp setting ? Looking for anyone that would know if that part number (which seems to be an Audi part number) indicates AGM or not thanks
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    If it's the OEM battery, then it's AGM. But for charging, you'll be fine either way. AGM batteries like a bit more charging current, but they'll still charge in either setting.
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Quote Originally Posted by mrg_B8TFSi View Post
    ... I have what I think is the original battery it’s a Varta 8K0 915 105 F but I can’t find anything as to if it’s a conventional battery or an AGM and if there is a difference in the charging mode when on the 2amp setting ? Looking for anyone that would know if that part number (which seems to be an Audi part number) indicates AGM or not thanks..
    VAG part number 8K0 915 105 F is original spec for PR-J0Z (conventional flooded H9); this was in our '14 A4Q, too. See my VAG starter batteries guide here: https://www.vwvortex.com/threads/spe...codes.9490580/ --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Feb 15 2016
    Cambridge,Ontario
    yeah OEM is not always AGM , in fact its quite rare.. i think thats mine and not AGM...
    yup thats the exact one i just replaced last month on my 14 non AGM.
    i replaced it with a type 93 from costco
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    I went with the everstart platinum agm from walmart. Battery is made in Germany and other than the color/labels, it was exactly the same as the varta it replaced, for much less coin.
    Jul 16 2018
    Atlanta
    As noted, 8K0...F is H9 wet flood, not an AGM.
    Dec 24 2021
    Northeast PA
    Quote Originally Posted by Smac770 View Post
    Thanks Smac.. I was 99% certain based on how it looked but was looking for expert opinion
    Sep 28 2014
    NY/NJ metro area
    Really? That's news to me. My 2011 and my 2016 both came with AGM from the factory.
    Sep 28 2014
    NY/NJ metro area
    Just curious...how can you tell by looking at a battery if it's AGM or flooded? My AGM looks exactly the same as a flooded battery. The only AGM batteries that look different are spiral AGM like an Optima, for example. Non-spiral AGM don't look any different than a standard flooded battery.
    Jul 16 2018
    Atlanta
    AGM letters = AGM; EFB letters = EFB; no letters = wet flood.
    black case = maybe AGM, maybe EFB; translucent/gray case = probably wet flood.
    no sight glass = maybe anything; sight glass = wet flood.
    If there's no identification on the battery which you can look up, there's pretty much no way to authoritatively confirm the chemistry inside.
    Non-AGM in a black case - https://www.ebay.com/itm/191704012395
    Image of a wet flood sight glass - https://www.ebay.com/itm/165053835616
    Moll slaps a sticker over the sight glass, Varta does not - https://www.drive2.ru/l/548435851252597845/
    a proper wet flood, translucent case, sight glass - https://www.interstatebatteries.com/products/mtp-95r/h9
    So the correct answer? If it says AGM on it, it's AGM. Otherwise, look up the battery identification on the manufacture web site.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by RockJGC View Post
    you did well :)
    1976 Yamaha XS 360
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    stock battery in my 2011 (all depends on your pr codes)
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Sep 28 2014
    NY/NJ metro area
    you did well :)
    Maybe I just got lucky. LOL
    Feb 15 2016
    Cambridge,Ontario
    as pointed out may have depended on your options, my 2014 flood, my friends 2010 Flood, and my other buddy not sure what year, flood. i was beginning to think AGM was a myth till you posted :)
    1976 Yamaha XS 360
    Aug 31 2014
    NW OH USA
    Quote Originally Posted by bb-tt View Post
    Thanks for sharing this image, bb-tt. Looks like PR-J0B. Battery manufactured by Johnson Controls. Note the production date coded on the (-) terminal. --g
    Sep 28 2014
    NY/NJ metro area
    Yeah....I always had the idea that an AGM is the better choice for any battery that's mounted inside the car, even if it's in the trunk. My Jeep has the battery mounted under the front passenger seat and it too is an AGM. Actually, it has two AGM batteries under the front seat. It's a strange set up for sure.
    Jul 16 2018
    Atlanta
    The wagons definitely seemed to get AGM more than the sedans. Like bb-tt, my 09 avant came with 4F0...E H8 AGM (J0B). While I remember several had posted their 3.2L 09 sedans coming with H9 flood (J0Z). I don't know any spec that loaded out with H9 AGM (J0P), other than it is defined. I suspect the electric tailgate is what pushed avants to AGM.
    Dec 24 2021
    Northeast PA
    Battery type help
    Quote Originally Posted by DrGER View Post
    I brought up this interesting topic because I have this exact physical battery in my 2013 B8 petro not flex fuel (I have plastic intake) CAEB 2.0Tfsi and the only difference I see on this battery is that mine is 8K0 915 105 F and this battery in image clearly shows AGM. I went to Varta website couldn’t find any reference from the part number with the physical construction of the battery.. I’m not here to say flooded over glass mat I really don’t have any preference as long as my battery is charging correctly and is coded properly. However for discussions and forums to say there is a physical difference between AGM and flooded acid batteries is incorrect as we are seeing the batteries look identical
    Jul 16 2018
    Atlanta
    One says 4F0 915 105 E, one says 8K0 915 105 F. One is H8 size, one is H9 size. One has a black casing, one has a translucent casing. One says AGM, one does not. They are not identical.
    Apr 30 2018
    DFW, TX
    such a stickler for the details
    WPT+
    Dec 01 2020
    2014 Q5 2.0T
    I have a Q5 but the 3D0 915 105 H that I replaced 2+ years ago clearly says "AGM" on the top label (right above the BEM code).
    Aug 31 2014
    NW OH USA
    Quote Originally Posted by silver_tt View Post
    Likely PR-J1N: 75AH H7 ? --g
    Dec 01 2020
    2014 Q5 2.0T
    Yes 75 Ah
